Enabling Bluetooth on 8845
shiblyibrahim
Level 3
Level 3
Hey,
Has anyone experienced issue with 8845 missing the bluetooth option though Cisco suggests it supports bluetooth.
Thanks in advance
Please rate the post Shibly Ibrahim
10 Replies 10
Deepak Rawat
Mohammed,
Are you not able to see the Bluetooth option when you press Applications on your IP Phone as mentioned in below document:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/userguide/P881_BK_CC6C5F2C_00_cisco-ip-phone-8800_series.pdf
Deepak
Hey Deepak,
I am unable to see this option unfortunately. Not sure if its a service now?
Have you enabled the Bluetooth setting and Handsfree for the Bluetooth Profiles settings from the phone page on CUCM.
Deepak
Hi Deepak yes I have
What all options do you see under Applications >> Preferences
Deepak
What is the exact CM version and firmware you are using there. Did you try on any other 8845 phone in your setup
Hey Deepak,
Yes we have.
System version: 10.5.2.11900-3
Firmware:
sip8845_65.10-3-2-16
Hey Deepak,
We have resolved the issue. The Enterprise Phone Configuration was overriding the phone settings and common device settings which is not correct. Suspect a bub but by enabling bluetooth on enterprise phone configuration we now have the correct setting and can use bluetooth on the 8845 phones.
I can't see the Bluetooth option in the settings.
