Enabling/Disabling Mobility
Chris Pohlad-Thomas
I have a softkey on my IP phone already, but I was wondering if there was a way to disable mobility from the web interface. Do I just need to change the setting to Off on the main device page?
Chris Deren
Yes, you can do that from ccmuser page.
Hth,
Chris
So I guess you'd disable the
"Enable Reach Me Anywhere so that my calls can ring at multiple numbers"
option?
Is there a good way to handle this administratively if say that user is unable to connect to that site?
Bump
