07-11-2012 03:35 AM - edited 03-16-2019 12:08 PM
How to enable FAC on cme or 00 calls
Please dind the below vg and cmd version
ios version: c2900-universalk9-mz.SPA.150-1.M3.bin
CME version :Version 7.1
please advise
Solved! Go to Solution.
07-11-2012 04:06 AM
Raja,
CME 7.1 does not support FAC natively as far as I know. You will need to use TCL scripts to achive this. Here is a link to how this can be done using TCL script. The script is also provided and sample configurations. Please note that this TCL is not supported by cisco TAC,
ftp://ftpeng.cisco.com/sbcs/doc/CME-FAC-Code.zip
You can upgrade your cme to 8.5/8.6 and you can do FAC natively
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
07-11-2012 03:57 AM
HI
Have you refered below link, it has configuration example.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
Ronak Patel
Rate helpful posts.
07-11-2012 04:06 AM
Thanks Ronak
But looks i need to upgrade the cme to 8.5 or above
is the 8.8 is stable version ?
planing to go for that with the ios version c2900-universalk9-mz.SPA.152-1.T2.bin
as per the below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
plz advise
07-11-2012 04:12 AM
Hi Raja,
My Apology for not seeing your CME version.
You need 8.5 and later versions.
I would suggest CME 8.6 with 15.1(4)M. As I believe Main line releases are better pick compared to T trains if you do not need more feature.
Ronak Patel
rate helpful posts.
07-11-2012 04:06 AM
Raja,
07-11-2012 04:12 AM
Shall i upgrade to 8.8 with the ios
and my vg is CISCO2901 it has 512dram/256 flash
