Enter SIP Credentials in 3905
W S H FERNANDO
Level 4
Level 4
How can I enter SIP credentials in Cisco 3905 phone ?
Regds
paolo bevilacqua
Are you using the phone with a non-cisco call control?
If yes, this is not the right forum, because cisco does not diclose and does not support that. You can try looking on other sites like www.voip-info.org.
Hi Paolo
No i'm using CME 9.0. with 3905 sip phone,
So how can i give the username and password (which i created on device pool ) to the 3905 phone ?
I tried with GUI but i cant find a place to submit it !!
Regds
hi
I have the same problem, what the problem is solved?
please provide me the solution
im using cucm 8.6.2
rgds
1.Create a EndUser in CUCM (give simple credentials to password and PIN fot testing 123456 like that)
2. Add the phone, (3905)
3. Assign the EndUser to the phone (digest user)- Select the digest user in the phone.
4. Reset the phone
Regds
