Enterprise License Manager - Failure to add Product Instance
mcibanez
I'm testing ELM co-res on CUCM.
I've just installed CUCM, started all services and changed name by IP@ in System>Server
I can access the ELM using the application username defined in the CUCM installation, but when I use the same one to add the product instance (that is, the CUCM) I get the following error: Test connection failed. Login failed while attempting to connect to the Product Instance. Verify that the porvided username and password are correct.
I don't understand what can be wrong with the username/pwd as it is the same I'm using to access CUCM and ELM and I can access both with no problem. Does this user has to have any additional role? I've been reading through the ELM user guide and I can find nothing else I should do before adding an instance.
Any help would be highly appreciated.
Carmen
josepaulopetry
hello,
you need to use the "OS Admin" username/password
is the same username/pwd that you use to SSH to the server
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/elmuserguide/9_0_1/CUCM_BK_E596FD72_00_enterprise-license-manager-user-90_chapter_011.html#CUCM_TK_A7019CC1_00
Note
Credentials are the OS Administration username and password of the product.
5 Replies 5
Rob Huffman
Hi Carmen,
There are some troubleshooting tips here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/elmuserguide/9_0_1/CUCM_BK_E596FD72_00_enterprise-license-manager-user-90_chapter_0101.html
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Thanks Rob, but I already looked at these and none of them match my problem... :-(
josepaulopetry
hello,
Note
Many thanks!!!
I was so blind I didn't see it
Nice find +5
Cheers!
Rob
