TFTP uses UDP port 69 to establish network connections. However, the data transfer ports (i.e. Ephemeral Ports) are selected dynamically by the sender and receiver when the connection is initialized.
As per RFC 2705, Port 2727 is used to send commands from MGCP Gateway to Call Control Agent and Port 2427 is used to send commands from Call Control Agent to MGCP Gateway.
In Cisco UC environment, Port 2427 used for bidirectional communication between CUCM and MGCP Gateway. Port 2727 is not used.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
