SIP Trunk CFwdBusy to Voicemail?
Randall White
Level 3
Level 3
I have a 3rd party IVR that connects to CallManager by a SIP trunk. Is there any way to forward calls to voicemail or another device if the SIP trunk returns a 486 BUSY HERE ?
This IVR is only licensed for a certain number of concurrent calls. Right now, if call volume is higher than the licensed amount, the caller hears a busy signal. When that happens, I would like to forward the call to a backup hunt group or voicemail box.
Any ideas?
Thanks, Randy
Jaime Valencia
I'm afraid you can't, once the call goes via a route pattern, it will only go through the route group(s) and route list for routing.
java
if this helps, please rate
Jaime Valencia
java
Thanks, I was afraid of that. I could bounce the call through CUBE, but then the call flow gets kind of messy.
Correct, that would be the only solution, send the call back to CUCM via CUBE/GW after CUCM sent the call out via a RP.
java
Anthony Holloway
If your voicemail is configured as a SIP trunk, you could add it as a secondary option to your RL/RG construct.
