Ephone-dn trying to register to Sip-ua!
asbesi001
After configuring SIP-UA on CME, I see that besides the username there are also all my ephone-dn trying to register to that SIP Server.
the ephone-dn is configured with no-reg both commend as below:
ephone-dn  1  dual-line
 number 234 no-reg both
 pickup-group 1060
 description Test
 name Test
 ephone-dn-template 1
also under the telephony-service the no-reg both command is applied:
telephony-service
 no auto-reg-ephone
 max-ephones 80
 max-dn 160 no-reg both
is there any other possibility to stop ephone-dn numbers trying to register to SIP-UA?
BRs,
bj
Manish Gogna
Hi BJ,
Can you try the workaround as per the following bug and also check if you are running one of the fixed versions of IOS
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsb76690/?reffering_site=dumpcr
Manish
asbesi001
any suggestions on this issue I ma facing?
below is the debug from one extension trying to register to SIP Provider and this goes with each extensions configured on the CME:
REGISTER sip:sip.example.net:5060 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK166926F3
To: <sip:234@sip.example.net>
Date: Fri, 28 Apr 2017 08:06:38 GMT
Call-ID: EFCC42EE-2B1E11E7-B2E285EC-8FB7C6D3
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1493366798
CSeq: 5 REGISTER
Contact: <sip:234@X.X.X.X:5060>
Expires:  3600
Content-Length: 0
thanks,
bj
Manish Gogna
Hi BJ,
Manish
thanks a lot Manish,
it worked as per the bug workaround description, it just needed to restart the CME and now only the specified user is registering with SIP-UA.
Best regards,
BJ
Good to know that it worked with the universal age old trick of a reboot :) thanks for updating the post.
Manish
