Ephone-dn & Voice Translation Profile
Hi all,
I have 45 ephone-dn´s
The target is that one ephone-dn off these is only reachable from only one special dn. But a corlist is not the right option.
The traget is that when a phone calls the one ephone-dn the call is directed to the spezial Phone that can call the one dn.
example:
ephone-dn 1
number 140 (the one that should be only call from one special dn)
ephone-dn 2
number 141 (this dn soelde be able to call ephone-dn 1)
ephone-dn 3
number 100 (when this phone call 140 the call should reach the dn with 141)
so corlist is not an option.
i tried to use a translation-profile "translate called x"
rule :rule 1 /140/ /141/
the "test voice translation-rule x 140 works perfect.
When I place this on a dn it did not work. I tried to place the profile on the internal voice-port or dial-peer but this peer and ports only for the system .....
But is there a way ?
Philipp
Ayodeji Okanlawon
What direction did you apply your voice translation rule? in or out? Translation rule applied to ephone-dn needs to be applied in   the inbound direction..e.g
ephone-dn 10
translation-profile incoming ephone
Please that there is a bug CSCeg65407 - translation-profile does not work on a ephone-dn on CME router
Symptom: Voice Translation-profile feature does not work on a Ephone of a
Cisco Callmanager Express router running Cisco IOS versions 123-11T2 or 123-
11XL.
Work-around: Use translation rule on pots or voip dial-peers to change the
number(s).
I believe this is fixed in 12.4 (latest) and upwards.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Ayodeji Okanlawon
ephone-dn 10
11XL.
number(s).
hm,
my config:
voice translation-rule 2
rule 1 /140/ /141/
voice translation-profile BM_to_VZ
translate called 2
ephone-dn 1
number 140
ephone-dn 2
number 141
ephone-dn x
number x
translation-profile outgoing BM_to_VZ
The Target behind :When a user call 140 the call goes to 141. The DN with the number 141 is the only number that sould reach the number 140
IOS Version : 15.1 on Cisco2921 SRST-CME Bundle
CME Version 8.1 that says CCP......
I use the CLI to configure
The Rule works perfect, but on witch dial-peer the profile not work. SO i need an outgoing dialpeer because of one dn that cann reach dn 1...................
destribute this translation through template etc or is there another way ?
on my configured dial-peers it won´t work because of "closest match" the systen would use the interna DIalpeer 20001 that is assoiate with ephone-dn 1 nor the voice-port 50/0/1.....
Bad trap i think :-)
corlist i come and a good apology to my customer :-)
OK call me Blind
IOS was ok but the logic off Dial-peers block the way to accept that the DIal-peers on dn´s must be inmplent the oposite way.............
