Err: SSL certificate error, Unity Connection
hutto.txed.net
When changing the greeting recording on my Unity Connection, version: 8.5.1ES47.12900-47 Unrestricted, I get the following SSL certificate error.
Unable to save recording due to SSL certificate error.
Would you like to accept the SSL certificate for this session and attempt to save the recording again?
When I select OK to try again, I don't get the same message again, when I select save but noting happens and the greeting
does not save.
I am Using Firefox 18.1 and also IE 9 get the same error
islam.kamal
Level 10
Level 10
Dear
you have to  check Trust the certificate  .
Thank you
please rate if this will help
