Incoming call info on 2nd line
Sarah Pongres
Hello Experts -
We are running Cisco Call Manager 8.5 with 7960 series phones.  We configure our agents' phones to have their Cisco agent ID as their first line and their DID number as their 2nd line.
When agents are on an incoming call via their Cisco agent ID, and a call comes in to their 2nd line on their DID, is there a way for the agent to see the complete incoming call info (name and extension) of that 2nd incoming call without putting the first call on hold?
They do get a small bit of info on the lower left corner of the phone display, it says "From xxxx", with xxxx being the extension number.
They would really like the bigger display pane of information that gives the name and extension of the call coming intot their 2nd line.
Is there a way to do this on a phone-by-phone basis?  I have searched and searched the system and service parameters, but haven't had any luck.
Thank you
SP
Rob Huffman
Hi Sarah,
On the individual device page > down towards the bottom
look for > Product Specific Config layout> Auto Line Select
and set to enabled
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Rob Huffman
Hi Sarah,
and set to enabled
Cheers!
Rob
-The Clash
Shucks, I was focusing on the directory number page!!!
This worked great, thanks Rob!
Rob Huffman
Hi Sarah,
No worries.....to look there would be quite logical. Glad to be of
some small help here.
Cheers!
Rob
-The Clash
