Error adding a phone
dwerts1628
I'm trying to add a phone that was previously registered but now, as far as I can tell, does not show up at all in Call Manager.  I am receiving this message:  Add failed. Could not insert new row - duplicate value in a UNIQUE INDEX column (Unique Index:device_name)
Any help would be appreciated
10 Replies 10
Aditya Gupta
Seems like there is still a stale entry in the database that is causing the issue while adding the phone.
Can you get me the output of following sql query on cucm nodes:
run sql select pkid,name from device where name = 'SEP<MAC>'
SEP<MAC> = SEP + MAC address of device you are trying to add.
Also check if there is any replication issue on your cucm cluster
Aditya Gupta
Thanks for taking the time to answer my question.  I am very new to Cisco VOIP so excuse my ignorance.  I attempted to run the query you requested but appear to be doing something wrong as I am getting a syntax error
No worries.. just paste the screenshot of the query you ran and error message you got.
that's not the correct format. Paste the query as i have written below:
run sql select pkid,name from device where name = 'SEP1CAA07108E0A'
Aditya Gupta
Returns:
The specified table (devices) is not in the database
Table name is device not devices
Aditya Gupta
Hi Aditya,
Do you remember the extension that was assigned to the same phone previously?
If yes, then check the extension and it's dependency records. If you don't find any dependency records then try to add phone with different mac address first with the same extension as earlier and then try to modify the mac address again.
Also, try to add phones in all the nodes one by one (i.e PUB and your available SUB's)
Nishant
Regards, Nishant Savalia
Thank you.  I will check
I hate to ask this question but have you searched for a Phone
based on -> Device name -> contains -> 1CAA07108E0A
Please don't be insulted, but I haven't seen a posting that stated this has been done.
