03-04-2011 07:29 AM - edited 03-16-2019 03:47 AM
Hi there, none of the MWI's are working at a customer's site . I logged on to Unity and tried the resynchronize all with the Depot Tool. However, I received this error message - " Unable to forward MWI synchronization request to Cisco Unity. Verify that the Cisco Unity Services are running ". I can verify that all services are running . I rebooted the server but the same problem and error message exists. Has anyone seen this error before or have any information that may help ? Many thanks,
Máire.
Solved! Go to Solution.
03-04-2011 07:47 AM
Hi Marie
Open CMD -->services.msc
++check whether the Avnotifier service is the start state, try restarting it.
and check it's logon account should be unitymsgstore account.
Vidit
03-04-2011 07:47 AM
Hi Marie
Vidit
03-04-2011 08:21 AM
Hi Vidit, thank you for your reply . When I run AvNotifierMgr, it starts and then stops again , it says it has no work to do . Any ideas ? The login is set correctly .
Many thanks,
Maire.
03-04-2011 09:05 AM
Hi Marie
Please provide the exact error you receive while starting the Avnotifier service.
-Vid
03-04-2011 09:31 AM
Hi Vid, the service is set to manual and when I try to start it , the error is " The AvNotifierMgr service on Local Computer started and then stopped. Some services stop automatically if they have no work to do , for example teh performance logs and Alert services. "
Many thanks,
Máire
03-04-2011 09:38 AM
Hi Maire
Were the Unity accounts moved to any other exchange server??
If yes , re-run the permissions wizrad which is presnt in the Cisco Unity Tools Depot with an account that has the domian admin rights.
Vid
03-07-2011 02:17 AM
Hi Vidit, the customer has migrated some
voicemail boxes to Exchange 2007 . I have not ran the permissions wisard yet . I think it is best out of office hours. I have created a back up, is there anything else I should be aware off while running the permissions wisard ?
Many thanks,
Máire.
