Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error: Line mode can't be changed while adding a new ephone
VAbr AVib
When i try to add a new ephone in CME, i get this below error.
Error: Line mode can't be changed, need to remove the dn and reconfig again.
Commands entered for the ephone creation:
ephone-dn  15 dual-line
number 3250
label Phone A-3250
description 3250
name Phone A
call-forward busy 3000
call-forward noan 3000 timeout 20
paolo bevilacqua
Correct.
Now follow what the router is telling you to do.
I am Sorry, i did not get your point !
Is this an error or am i doing a wrong configuration ?
Hope this is nothing to do with phone licenses ?
As above: just read and follow what the line you set in bold says.
Rob Huffman
Hi Vibi,
Paolo is most correct +5
What the line is telling you is detailed in the command notes;
Ephone-dns are created in single-line mode if the
dual-line
or
octo-line
keyword is not used. To change an ephone-dn from one mode to another,  for example from dual-line mode to single-line mode, you must delete the  ephone-dn and then re-create it.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_e1ht.html#wp1065555
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
