10-09-2016 10:42 PM - edited 03-17-2019 08:18 AM
When i login into cups pub its pop ups with this error "Error Occured While retrieving information from database.The connection to the CUCM Publisher is down"
Db replication
Index error :List Index out of range.
Please let me know the fix.
10-09-2016 10:48 PM
Is your CM publisher up?? Provide the output of show tech network hosts and show version active from your IM&P and CM server
Deepak
10-10-2016 01:44 AM
CUCM | 10.5.2.13901-2 |
PRESENCE | 10.5.2.23900-4 |
10-13-2016 08:58 AM
10-09-2016 10:50 PM
Please send the output of the following from CUPS PUB and CUCM PUB
Utils service list
utils dbreplication runtimestate
utils ntp status
utils diagnose test
show status
show version active
1. Have you tried rebooting the cluster?
2. Is it a new installation or you recently upgraded IM&P? If you have upgraded IM&P then make sure the base version should match it with what you have on CUCM. for example if CUCM is 10.5.2SU1 then the base version for IM&P should also be 10.5.2.
Aseem
10-10-2016 04:15 AM
I have tried to restart CUPS PUB now cisco DB is not running.
Services starting taking long time to come up some not yet up and running.
vcpu 0 and memmory 0
please advice..
