ā03-08-2023 08:52 AM
I have downloaded from Software Download - Cisco Systems the below CME-14 files but not able to load onto the CLI of ISR 4000 using command
archive tar /xtract tftp://172.21.24.17/ CME-COMPLETE-FILESET-14.1.tar flash:
Error on router and tftp shown as below
%Error opening tftp://172.21.24.17/CME-COMPLETE-FILESET-14.1.tar (No such file or directory)
Please advise how and which file to load as .tar.
I extracted from zip file downloaded - CME-COMPLETE-FILESET-14.1 but inside these there are many other zip files. So which tar file should I upload.
I referred to doc: https://support.hpe.com/hpesc/public/docDisplay?docId=c02049236
& https://support.hpe.com/hpesc/public/docDisplay?docId=c02049236
ā03-08-2023 09:16 AM
What is it that youāre looking to achieve and why are you looking at guidelines from HPE for this?
Not sure if itās a typo in the post, but there is a space in the path that you have.
ā03-08-2023 09:20 AM
Yes its typo:
Path as below:
archive tar /xtract tftp://172.21.24.17/CME-COMPLETE-FILESET-14.1.tar flash:
but not working
ā03-08-2023 09:41 AM
What about the other parts of my questions? What is it youāre trying to accomplish by this and why are you using guides from HPE for this.
ā03-08-2023 11:19 AM
I found hp doc in google search for cme install files
ā03-08-2023 10:12 AM
Those documents on HPE are incorrect. CME is a part of IOS, you can not install a new version of CME on a router by unpacking a file. Youāll need to download and update IOS on the router to get a new version of CME.
ā03-08-2023 11:20 AM
Kindly clarify how to do this?
I upgraded the router os to 17.6
ā03-08-2023 11:45 AM
ā03-08-2023 11:52 AM - edited ā03-09-2023 03:25 AM
With that version of IOS you already have the latest version of CME.
ā03-09-2023 04:15 AM - edited ā03-09-2023 04:15 AM
I do not find CME in the router license output or in configuration.
I have ephone dn and added mac addresses as well to telephony service and create cnf
Only uck9 license there
Even on smart account portal the cme license does not show as IN USE
And the ip phone are still showing as unprovisioned
ā03-09-2023 12:54 AM - edited ā03-09-2023 12:55 AM
CME is automatically upgraded, when you upgrade the router os (as you call it) => The OS is called IOS or IOS-XE.
You cannot upgrade CME software standalone.
And it would be more helpful, to answer @Roger Kallberg question, what you are trying to achieve?
ā03-09-2023 04:18 AM
I am trying to activate ip phones for internal calling by activating them using the purchased 28 cme14-ul license. Is is the phones are still showing as un provisioned , license output& smart account portal does outpu does not show cme license IN USE
