ESXi 4.1 Update 1
DOUG DAVIDSON
Level 5
Level 5
Is ESXi Version 4.1 Update 1 supported for CUCM, Unity Connection, UCCX and Presence?
Doug
phooghen
Doug,
Have a look at:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
Pierre.
ESXi Support for Call Processing and System Management Applications
Application
VMware vSphere ESXi 4.0 or 4.0 Update 1
VMware vSphere ESXi 4.1
Unified Communications Manager8.0(2) and later8.0(3) and later
Unified Communications Manager Business Edition 60008.5(1) and later8.5(1) and later
Cisco Emergency Responder8.5(1) and laterNot supported
Session Manager Edition8.5(1) and later8.5(1) and later
Unified Attendant Consoles8.0(3) and laterNot supported
UC Management Suite (OM, SM, SSM, PM)7.1 and later7.1 and later
ESXi Support for Messaging and Presence Applications
Application
Cisco Unity Connection8.0(2) and later8.0(3) and later
Cisco Unity7.x and later7.x and later
Cisco Unified Presence8.0(2) and later8.0(2) and later
ESXi Support for Contact Center Applications
NoteNote:For  Virtual Machines that need more than 4 vCPUs, the VMware vSphere ESXi Enterprise Plus licensing is required (8 way virtual SMP capability). The VMware  vSphere Enterprise Plus license can be procured from the Cisco  build-to-order or directly from the VMware (see VMware Purchasing  section above.)
Application VMware vSphere ESXi 4.0 or 4.0 Update 1 VMware vSphere ESXi 4.1
Unified Contact Center Express / IP IVR8.0(2) and later or 8.5(1) and later8.0(2) SU2 and later or 8.5(1) and later
Cisco Unified Workforce Optimization (WFO), Quality Manager (QM), and WorkForce Management (WFM)8.5(1) and laterNot supported
Unified Contact Center Enterprise See belowSee below
- Router, Logger, Rogger, Agent PG, MR PG, VRU PG, Administration  and Data Server (AW, AW-CONFIG, AW-HDS, AW-HDS-DDS, HDS-DDS),  Administration Client, Outbound Option with SIP Dialer, Support Tools8.0(2) and later or 8.5(1) and laterNot supported
- Progger, Unified ICME/CCH/ICMH, Outbound Option with SCCP Dialer,  Webview, EIM/WIM, Expert Advisor, RSM, Unified CRM ConnectorNot supportedNot supported
Unified Intelligence Center 8.0(3) and laterNot supported
Unified Contact Center Management Portal8.0(2) and later or 8.5(1) and laterNot supported
Unified Customer Voice Portal (all components) 8.0(1) and later or 8.5(1) and laterNot supported
Cisco MediaSense8.5(1) and later8.5(2) and later
Cisco SocialMiner8.5(1) and laterNot supported
I do not see Update 1 listed as supported, so I am going to assume that it is not supported, yet.
After some additional searching on VMware site, I found the following file, VMware-VMvisor-Installer-4.1.0-260247_Cisco.iso, is that the correct one to use for a C210?
Doug
Doug,
I don't know if Update 1 is supported or not by Cisco, but I've seen a few customers who downloaded Update 1 from VMware and have installed it.
(Update 1 is not provided by Cisco but by VMWare).
Concerning the ISO file, I think you need:
http://downloads.vmware.com/d/details/esxi41_cisco_oem_iso/ZCV0YnRkdHdiZHdldA==
Pierre.
