10-07-2013 06:16 AM - edited 03-16-2019 07:44 PM
I want to activate the 8FXS on my Gateway ( 2921 ), can you help me with the proper step/command to be able to activate the port.
Cisco CISCO2921/K9 (revision 1.0) with 884736K/49152K bytes of memory.
Processor board ID xxxxxxxxxxx
3 Gigabit Ethernet interfaces
108 Serial interfaces
4 ISDN Basic Rate interfaces
1 terminal line
4 Channelized E1/PRI ports
24 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Solved! Go to Solution.
10-16-2013 04:17 AM
replace the 8.6 with 3.1
Tony
Please rate helpful posts!
10-16-2013 06:34 AM
Hey Tony,
This is what I receive after I made the changes,then what I have to do ?
Th
show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 10.x.x.x
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.x.x.x, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 2
Trustpoint: N/A
Call Manager: 10.0.0.0, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Trustpoint: N/A
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
10-16-2013 06:43 AM
Did you create the ccmgroup like I posted above? Do the following -
sh sccp ccm group
If there is nothing there do the following -
conf terminal
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
exit
Tony
10-16-2013 06:53 AM
After in type:
show sccp ccm group
CCM Group Identifier: 1
Description: None
Binded Interface: None
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 2, Priority in this CCM Group: 2
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
And when I write:
conf terminal
sccp ccm group 1
I received: The specified CCM is already associated to the selected CCM group.
10-16-2013 06:56 AM
Then you are good to go from a basic SCCP standpoint!
Tony
10-17-2013 12:35 AM
Hi Tony,
On the CallManager what settings I have to do/add/modified ?
Th for help
10-17-2013 04:24 AM
It depends on what you are trying to accomplish. From what I have read, you are replacing an ATA with a 2921 for faxing. How does this fax machine terminate?
Tony
10-17-2013 06:59 AM
I just want to replace ATA with the 8FXS/DID, we have 12 Fax nr which in this moment are on the Ata moduls.
10-18-2013 05:16 AM
show voice call:
1/0/0 - - - vpm level 1 state = FXSLS_ONHOOK
vpm level 0 state = S_UP
1/0/1 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/2 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/3 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/4 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/5 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/6 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/7 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/8 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/9 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/10 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/11 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/12 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/13 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/14 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/15 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/16 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/17 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/18 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/19 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/20 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/21 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/22 - - - vpm level 1 state = FXSLS_ONHOOK
1/0/23 - - - vpm level 1 state = FXSLS_ONHOOK
10-18-2013 05:36 AM
I would start by building a 2921 gateway within Call Manager. Once created, choose the module contained in the specific slot. In this case it may be an EVM-HD and then in subunit select your 8FXS/DID. Then build your ports.
Tony
11-05-2013 02:17 AM
Hey,
Some friend help me to add the EVM-HD-8FXS/did to Gateway, but I can't make calls.
1.
2.
3.
4.
11-05-2013 08:33 PM
Are they showing registered?
Is your phone you are dialing from configured with proper CSS that can reach the DN's partition.
Chris
