EX90 can't redail missed calls
iptsupport
Level 4
Level 4
Hello ,
My ex90 it  registered to CUCM 10 when the  ex90 is able to call and get calls but when I try to call back missed calls it seems
the ex90 trying to call the domain of the company  .
Any idea ?
Manish Gogna
Is the EX90 able to dial the same address that is saved in the missed calls history if you dial it normally from the endpoint? If yes, then you should get detailed callmanager service trace for both scenarios to check the digit analysis which will show if the correct route pattern is invoked in the non-working scenario.
Manish
It seems that when I call to answered number it's working only when I try to callback to
to missed calls the phone is trying call the URI the domain of the company for example
Phone A call ex90 . ex90 don't answer the and then try to redail the number .
The station is calling domain.com
