07-16-2011 05:21 PM - edited 03-16-2019 05:58 AM
Wondering if someone can post up the contents of their (UK based) g4-tones.xml file?
Thanks in advance.
Sean
Solved! Go to Solution.
07-17-2011 08:54 AM
CME locales are simply zip files.
Thanks for the nice rating and good luck!
07-17-2011 03:15 AM
The file you're asking about is contained in CME 8.6 locale, that you can download from cisco.com.
There is no need to re-invent it.
07-17-2011 07:42 AM
Cheers Paolo,
Reason I'm asking (maybe I should have been more explicit in my initial post) is that I'm using Asterisk rather than CME with my 99xx SIP handsets.
Therefore I have no way of getting at the g4-tones.xml file within the Cisco CME locale package - although I have downloaded a copy of the relevant po-locale-en_GB-9.2.1.1000-1.cop.sgn file. Unless there is a clever way of extracting said file without using CME?
Sean
07-17-2011 08:54 AM
07-17-2011 10:12 AM
Perfect! Many thanks Paolo.
