Expansion key's for 9971
ali nasser
Can we change the background for the expansion key's for 9971 (CKM).
Ali Nasser
ichehouri
Level 2
Level 2
our customer is asking the same question. is this supported of not? please let us know
regards,
Ibrahim
It's not possible to change the background of the sidecars.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
thanks java for the reply
regards,
Ibrahim
