IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5619 Views
  • 14 replies
Hi for every body,I have cisco callmanager ver 7.1 and MGCP gateway that contains 12 FXO lines , the customer needs his operator that has 7865 phone with 2 expansion module to monitor all these lines in which if he has a call from any person needs to...
Hello,is there any way in a CUBE router to use the SIP INVITE's "contact" info to be used as clid, when being converted in an ISDN call?Usually this value is taken from the SIP "from". In my case, depending on the service, the other end will use a di...
matigil by Level 1
  • 474 Views
  • 1 replies
  I've just put a + in front of all our numbers in AD and have found that our Attendant Console will not dial these numbers. We get a busy tone like the call can not be competed as dialed. What do I need to do on CM to get the + sign recognized or ig...
anthonymd by Level 1
  • 490 Views
  • 4 replies
Hi,I have been trying to find a documenation to guide me to configure SIP Gateway that connect to PSTN.Here is the scenarios:The SIP Provider will drop 10MB (Dedicated) which conenct to Gigbit Ethernet (Cisco 2911)I will assume after configuration, t...
kenh by Level 1
  • 3144 Views
  • 2 replies
Hi ,We want to configure the application dial rule which is matching variable numbers.In CUCM  Admin guide it's mention asNumber of DigitsEnter the length of the dialed numbers to which you want to apply this application dial rule. Enter a number of ...
