Expansion Module issue
Muhammad Talha
Expansion module is detected by 8851 but unable to configure it on cucm snap attached
Les Pruden
Level 4
Level 4
Hi -
Make sure you have created and applied a phone button template to support the module and that you've configured the Expansion Module Information section on the Device page.
For Example
Phone Button Template --> Standard 8851 SIP 2L 3SD 36BLF
Expansion Module Information --> Module 1 --> BEKEM 36-Button Line Expansion Module
sharkaev1
Hello! how a button template you use?
vince.castro
hi talhaharoon,
still having this issue? your capture is on the device page and should be under the Related Links area, but 2 things to be able to configure the side car.
1. Define the device page to have an expansion module.
2. make sure the phone has the correct button template to accommodate the side car.
