Hi All,
Please help me with the below query
I have cucm 10.5 cluster.
There are some CAPF trust certs which are expired.I would like to know if I delete the CAPF trust, how it can be regenerated.
What would be the impact of deleting the expired CAPF Trust.
Is there any procedure to follow before deleting the expired CAPF Trust.
please help.
Saifudeen
Renew/regenerate the capf cert on the cucm on which it expired. The upload that cert into the capf trust store of the others. And restart the capf service on all servers in cluster.
The procedure is outlined here, and there are several other threads and references to certificate regeneration/renewal.
Special care if you're using mixed mode or the CTL for some other purpose, if not, it will be easier.
Hello Jaime,
Thank you so much for your response.
1.I am still not clear how the trust certificates will be recreated, if all are expired.
2.How can we know which CAPF certificate is in use.
Saifudeen
