Expressway 12.7.1 remove/disable CBC ciphers for SSH
themizzz21
A penetration test revieled that ssh on expressways have CBC mode ciphers enabled and they asked to disable this.
Pen test result: "We have managed to identify that the SSH server running on the remote host is configured to support Cipher Block Chaining (CBC) encryption."
Pen test recommendation: "You should disable the CBC mode cipher encryption and enable CTR or GCM cipher mode encryption instead."
The CLI command "xconfiguration // cipher" shows
xConfiguration Ciphers sshd_ciphers Value: "aes256-gcm@openssh.com,aes128-gcm@openssh.com,aes256-ctr,aes192-ctr,aes128-ctr"
Is there any CLI command that could disable the proposal of aes256-cbc ciphers
Thank you very much,
5 Replies 5
b.winter
I think, it's possible to edit (add, delete) the ciphers via GUI.
I currently don't have access to an EXP to give you the correct page-path.
But be careful when editing them. There maybe some interop issues to other systems then. Good advice is to take a backup first or note down the changes.
The ssh page regarding ciphers is completely different  than the other protocols(https, sip etc).
As far as I can see there is no way to delete/disable ssh ciphers within gui.
Thanks.
But there is a different page for SSH configuration under "Maintenance" --> "Security" --> "SSH Configuration":
The 12.7.1 version has no "Remote Access Configuration"
What is your version?
Thank you.
I'm on a version X14.0.5
