09-29-2017 09:28 AM - edited 03-17-2019 11:16 AM
Hello Community,
i have cucm version 11.5(1)SU3, (CMS: 2.2.8, Expressways: X8.10.2)
the region settings are note configured and the "Default Interregion Max Video Call Bit Rate (Includes Audio)" Service Parameter is 6000.
now when i have a SIP B2B Call incoming or outgoing (CUCM->Expressway-C->Expressway-E->Internet) i always get 384 kbps as a call rate which is very low. From other customers i get much more to the same destination.
now when i make a SIP B2B Call to Skype for Business Cloud (CUCM->Expressway-C->CMS->Expressway-C->Expressway-E->Internet): i get a call rate of 2000 kpbs
when i make a call to CMS (CUCM->Expressway-C->CMS) i also get 2000 kpbs.
i tried a lot of older Expressway-Versions which make no different here. so i assume it is a CUCM Bug, but i can't find a Bug id?
Solved! Go to Solution.
10-02-2017 09:21 AM - edited 10-02-2017 09:27 AM
ok so this is what i can see.
this is an outgoing call:
Telepresence EX90 -> CUCM -> Expressway-C ->Expressway-E -> external SIP Plattform
the invites are without SDP, on Expressway-E i see:
incoming 200 OK with SDP:
v=0
o=Acano 0 0 IN IP4 192.168.x.x
s=-
c=IN IP4 193.x.x.x
b=AS:4000
t=0 0
m=audio 37426 RTP/AVP 108 107 96 109 110 9 99 111 100 104 103 0 8 15 102 18 13 118 101
b=TIAS:256000
%a lot of codecs%
m=video 37428 RTP/AVP 97 116 114 96 34 31 100 121
b=TIAS:3744000
%a lot of codecs%
m=video 37430 RTP/AVP 97 116 114 96 34 100 121
b=TIAS:4000000
a=content:slides
a=sendrecv
%a lot of codecs%
m=application 37434 UDP/UDT/IX *
then i see a 200 OK Send to Expressway-C with:
v=0
o=CiscoSystemsCCM-SIP 1560368 1 IN IP4 192.x.x.x
s=SIP Call
c=IN IP4 192.x.x.x
b=AS:384
t=0 0
i found out that someone put a Bandwidth PIPE Config with this limit :(
works now, could not imagine that it is simple as that, because calls to skype for business work with 2000 kpbs, nice to know that these calls completely ignore bandwith settings ;-)
09-29-2017 06:21 PM
Do you have any locations applied in UCM that are limiting your bandwidth?
10-01-2017 05:30 AM
Yes I have locations in place but they allow 12000 kbps for video
09-30-2017 08:19 AM
If you trace the call from cucm rtmt, what is the bw modifer negotiated during the call setup and which entity is forcing 384kbps.
CUCM will use the following rules to select the video bandwidth to be used during the call and communicated to endpoints in bandwidth modifiers:
10-01-2017 05:33 AM
Ok thanks i will Check that.
v=0
s=-
c=IN IP4 193.x.x.x
b=AS:4000
t=0 0
b=TIAS:256000
%a lot of codecs%
b=TIAS:3744000
%a lot of codecs%
b=TIAS:4000000
a=content:slides
a=sendrecv
%a lot of codecs%
v=0
s=SIP Call
c=IN IP4 192.x.x.x
b=AS:384
t=0 0
10-02-2017 09:47 AM
