Expressway E GUI Access gone after changing ipv4 gateway address
shihab.kp
Level 2
Level 2
we are having expressway dual nic setup.
in expressway e ip configuration i changed ipv4 gateway and given LAN2 Default gateway.
like the below snap
now web interface is not coming and please suggest how can i revert the configuration through cli.
#installwizard only able to set ip only
It is possible you will need a static route enabling the Expressway-E to respond to LAN traffic. Take a look at:
Expressway Basic Configuration Deployment Guide - Chapter: Advanced Networking Deployments/Static Routes Towards the Internal Network
Maren
As @Maren Mahoney wrote you need to add a static route on LAN1 that routes internal traffic to the router on that network. You can add that from the console CLI in VMware.
Response Signature
