Ext/DID is not coming from outsite.
shaikhugee
I have E1 ISDN plan with 10 segregated channels and 100 DID's which are connected to my Cisco Phone System UC560. I noticed today that one of the ext. and its associated DID is not working and giving busy tune when dialed from outside. Even when I try to dial from the Exchange using the main key the line drops when I dial the ext. User can dial normaly to any outside numbers using the ext. and the DID. Internally the ext is also working.
Below the ext configuration:
ephone-dn  112  dual-line
number 112 secondary 010000000 no-reg primary
pickup-group 1
label 112
description 112
name 112
call-forward noan 0 timeout 15
corlist incoming call-local
corlist outgoing call-local
ephone  16
device-security-mode none
mac-address 40F4.ECEE.D7A6
ephone-template 16
username "User12" password 123456
type 7942
button  1:112
The translation rules also looks fine to me.
Can someone let me know what and which configuration to check for this problem. Its URGENT.
11 Replies 11
shaikhugee
I even restarted the Phone System with no luck. Still I cannot dial from outside either ext or DID.
Can you call internally from another phone?
Is the corlist incoming and outgoing applied to this ephone-dn the same as other working ephone-dn?
Chris
Dear Chris,
Answers to both your queries is Yes.
I am not sure of UC500 debug capabilities, but are you able to run "debug isdn q931" for the failed call and post it?
Chris
debug isdn q931 is accepted but its giving options:
asn1       ISDN Q931 ASN1 detail
detail     ISDN Q931 packet detail
interface  Specify interface for debugging
What to choose here?
Chris,
I need some help to run this debug you asked as I am not familiar with the phone system.
Thanks.
Rejohn Cuares
Level 4
Level 4
Muhammad,
Perform this.
1. Login to UC560 through Telnet or SSH.
2. Go to Privilege Exec mode (e.g. uc560-hostname#) and enter the following.
terminal monitor
debug isdn q931
<-- This means you must press the Enter key on your keyboard.
3. From your mobile dial the E.164 number of x112.
If you see an output bearing your mobile ANI and DNIS of x112 (E.164) it means the issue is with your configuration, it might be your incoming translations. Otherwise problem with your ISDN provider.
Please rate replies and mark question as "answered" if applicable.
Dear Cuared,
This is what I got:
QIB-VG#
000391: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref =
0x7D28
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2183, '0555555555'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '0112'
                Plan:ISDN, Type:Unknown
        High Layer Compat i = 0x9181
000392: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: L3IF_rx_L2_pak: received dat
a
000393: Feb 27 07:05:26.112:    08027D2805A104038090A31803A98381
000394: Feb 27 07:05:26.112:    6C0C2183303535333130323234377005
000395: Feb 27 07:05:26.112:    81303131327D029181
000396: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: L3_Go: source 0x020A, ces 1,
event 0x0005, call id 0x0000, int id 0x0
000397: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: L3_Go: event 0x5  cr_len 2 c
r 64808
000398: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: L3_Go: call_id 0x1A cr 0xFD2
8 state 0 event 0x5 ces 1
000399: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: L3_ProcessEvent: callref = 0
xFD28 SETUP:U0_Setup(nlcb)
000400: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: L3_state_change: callref 0xF
D28 old NULL_STATE, new CALL_PRESENT
000401: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0xF
D28 callID = 0x001A switch = primary-net5 interface = User
000402: Feb 27 07:05:26.112: ISDN Se0/2/0:15 Q931d: extract_called_number: Extra
cted called number 0112
000403: Feb 27 07:05:26.116: ISDN Se0/2/0:15 Q931d: extract_called_number: Extra
000404: Feb 27 07:05:26.116: ISDN Se0/2/0:15 Q931d: extract_called_number: Extra
000405: Feb 27 07:05:26.116: ISDN Se0/2/0:15 Q931d: extract_called_number: Extra
000406: Feb 27 07:05:26.116: ISDN Se0/2/0:15 Q931d: extract_called_number: Extra
000407: Feb 27 07:05:26.116: ISDN Se0/2/0:15 Q931d: extract_called_number: Extra
000408: Feb 27 07:05:26.124: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name
in GTD
000409: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: CCIE_BuildChanId_IE: int_ide
nt_len 0
000410: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_Go: source 0x0400, ces 1,
event 0x0088, call id 0x001A, int id 0x0
000411: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_Go: event 0x88  cr_len 2
cr 64808
000412: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_Go: call_id 0x1A cr 0xFD2
8 state 6 event 0x88 ces 1
000413: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_ProcessEvent: callref = 0
xFD28 CC_CALL_PROC_REQ:U6_CallProcReq(nlcb)
000414: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: srl_send_l3_pak:
        source_id = Q.931 0x0300, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0
240
        priv_len = 4 int_id = 0x887629BC datasize = 26
000415: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: data =
000416: Feb 27 07:05:26.124:    887629BC000003000240040000010102
000417: Feb 27 07:05:26.124:    0802FD28021803A98381
000418: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_state_change: callref 0xF
D28 old CALL_PRESENT, new IN_CALL_PROC
000419: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_Go: source 0x0400, ces 1,
event 0x0084, call id 0x001A, int id 0x0
000420: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_Go: event 0x84  cr_len 2
cr 64808
000421: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_Go: call_id 0x1A cr 0xFD2
8 state 9 event 0x84 ces 1
000422: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_ProcessEvent: callref = 0
xFD28 CC_DISCONNECT_REQ:Ux_DiscReq(nlcb)
000423: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: srl_send_l3_pak:
240
        priv_len = 4 int_id = 0x887629BC datasize = 25
000424: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: data =
000425: Feb 27 07:05:26.124:    887629BC00000300024004000001010A
000426: Feb 27 07:05:26.124:    0802FD284508028081
000427: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931d: L3_state_change: callref 0xF
D28 old IN_CALL_PROC, new DISCONNECT_REQUEST
000428: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callr
ef = 0xFD28
000429: Feb 27 07:05:26.124: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  call
ref = 0xFD28
        Cause i = 0x8081 - Unallocated/unassigned number
000430: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref
= 0x7D28
000431: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: L3IF_rx_L2_pak: received dat
a
000432: Feb 27 07:05:26.436:    08027D284D
000433: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: L3_Go: source 0x020A, ces 1,
event 0x004D, call id 0x0000, int id 0x0
000434: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: L3_Go: event 0x4D  cr_len 2
cr 64808
000435: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: L3_Go: call_id 0x1A cr 0xFD2
8 state 11 event 0x4D ces 1
000436: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: L3_ProcessEvent: callref = 0
xFD28 RELEASE:U11_Release(nlcb)
000437: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: srl_send_l3_pak:
240
        priv_len = 4 int_id = 0x887629BC datasize = 21
000438: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: data =
000439: Feb 27 07:05:26.436:    887629BC00000300024004000001010A
000440: Feb 27 07:05:26.436:    0802FD285A
000441: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931d: L3_state_change: callref 0xF
D28 old DISCONNECT_REQUEST, new NULL_STATE
000442: Feb 27 07:05:26.436: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  ca
llref = 0xFD28 QIB-VG#
0x7D28
        Sending Complete
                Standard = CCITT
a
r 64808
in GTD
nt_len 0
cr 64808
240
cr 64808
240
ef = 0xFD28
ref = 0xFD28
= 0x7D28
a
cr 64808
240
llref = 0xFD28
VG#test voice translation-rule 6 3050112
Matched with rule 3
Original number: 3050112      Translated number: 112
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Test the voice traslation as well. The correct number is being resolved.
I really need someones help to resolve this problem.
I got my problem fixed by deleting the "num-exp 0 0100" entry and re-adding it so that it appears below the 112 entry.
num-exp 0112 112
num-exp 0 0100
