Extending the greeting recording timeframe for a call handler
KennyBBIT
I hope this is a simple question.  I'm still getting accustomed to this new IP phone system of ours and I can't seem to find a value to adjust for this user's request.  We have a call handler that we use to record bad weather memos for the company and its default greeting recording window is too short for management; they tend to get cut off before they can finish telling each division their schedules.  Is there a way to extend this recording timeframe to allow for a longer advisory message?
I'm using Cisco Unity Connection version: 10.5.1.10000-7 to manage VM, call handlers and the like.  I've found the 'Maximum message length' field, currently set to 300 seconds, but I believe that governs the messages left on a given voicemail box, not the greeting itself.
Rob Huffman
Hi Kenny,
My understanding is that the Greeting Length for a Call Handler is determined by the COS of the person recording the Greeting. Have a look;
Class of Service Greetings Settings
The class of service greetings setting specifies the maximum length of greetings.
Subscribers > Class of Service > Greetings Page
Field Considerations
Maximum Greeting Length in Seconds
Select the recording length allowed to subscribers assigned to this COS for recording greetings.
The range is 1 to 999 seconds; the default is 90 seconds.
Greeting Length
Do the following procedure to specify how long the recorded greeting of a user can be.
To Specify Maximum Length of User Greetings
Step 1 In Cisco Unity Connection Administration, find the COS that you want to change, or create a new one.
Step 2 On the Edit Class of Service page, under Greetings, enter the maximum length in seconds in the field.
Step 3 Click Save.
Cheers!
Rob
Rob Huffman
Hi Kenny,
Greeting Length
Step 3 Click Save.
Cheers!
Rob
If i upload an audio file bigger than 90 seconds i have to make this config?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
KennyBBIT
This appears to be perfect; I had not visited this section of the management area before.  I was able to confirm that the setting was currently set to 90 seconds (which I would have thought would be long enough) and confirm that this manager was a part of the selected COS group.  I'm optimistic that this will work and I appreciate the prompt (and thorough) answer.
