01-12-2015 01:31 PM - edited 03-17-2019 01:33 AM
Good afternoon. We are trying to implement a hunt group for our main switchboard. The scenario would be all calls to the home office come into a hunt pilot and then hunt, top down, to the main switchboard extension and then to a choice of 3 other devices that would be logged in. The problem is that we cannot get the hunt group to hunt longer than 1 minute. I have changed the RNA Reversion Timeout and with all the devices logged it, the call will only hunt until the 60 seconds has expired and then the call drops; 15 seconds at the RNA Reversion Timeout will get to all 4 devices - anything longer and the call drops before finishing the hunting process. From the information that I can find, a hunt group should "hunt" for up to 30 minutes (or so we read in the Hunt Pilot information). We're using a "Top Down" algorithm since we want all calls to always start at the switchboard directory number, and all of the Hunt Options are set to "Try Next member; then, try next group in Hunt List". The only place where we have indicated any time is on the Line Group - RNA Reversion Timeout. There are times where only the switchboard device may be logged into the hunt and we need to have that ring time at 60 seconds minimum for the call to be handled appropriately.
Is this a simple overlook on our part or are we limited in what we want to do?
Thanks for any insight that you can give us.
Cinde
01-15-2015 01:14 AM
Do you have a 'maximum hunt timer' specified on your hunt pilot?
Aaron
01-15-2015 04:54 AM
Aaron,
Thanks for the reply. No - we left the "Maximum Hunt timer" blank on the Hunt Pilot as we understood that, by default, it would hunt for 30 minutes if left blank. Is this not correct? Please advise.
Thanks!
01-15-2015 05:24 AM
In theory yes, but I'd try it.
Aaron
01-15-2015 06:10 AM
Aaron,
Thanks for the reply. Between you and Rob, I think we might have a solution. I will configure this in our test environment and let you know.
I appreciate all the helpful insight.
Have a good one!
Cinde
01-22-2015 09:35 AM
Aaron,
We tried Rob's suggestion above to no avail. The line groups/hunt pilot still will not hunt any longer than 1 minute. Any other suggestions?
Thanks.
Cinde
01-15-2015 05:50 AM
Hi Cinde,
I just wanted to add a note to the excellent tips from my friend Aaron here (+5 "A")
The Maximum Hunt Timer is only leveraged when considering it in conjunction with the Call Forward settings on the Hunt Pilot config as noted here;
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_5_1/ccmcfg/bccm-851-cm/b03htpil.html
There is an old bug that describes this in better detail;
So, to accomplish what you want you'll need to set up and link multiple Line Groups that contain the same 4 member DN's via the "Try next member,then try next Group in Hunt List" setting.
Let's say in our example the members of the first Line Group Called Main#1 are 3333,4444,5555 and 6666 then you create a second Line group called Main#2 that contains 3333,4444,5555 and 6666 and Main#3 that contains 3333,4444,5555 and 6666.
Include Main#1,Main#2 and Main#3 in the Hunt List; and Switch the rule on the first Line Group
to, Try next Member;then try next Group in Hunt List and Switch the rule on the Second Line
Group to, Try next Member;then try next Group in Hunt List.
This will then cycle through the Members 3333,4444,5555 and 6666 three complete times.
Cheers!
Rob
01-15-2015 06:09 AM
Rob,
I will give this a try in our test model and see if I can get it to accomplish our end goal. I will post back with results.
Thank you for your help with this. I hope this give us the result that we're looking for.
Have a great day!
Cinde
01-22-2015 09:36 AM
Rob,
We tried your suggestion above and the line group/hunt pilot would still not hunt for any longer than 1 minute. Do you have any other suggestions?
Thanks.
Cinde
