02-14-2017 03:12 AM - edited 03-17-2019 09:31 AM
Dear All,
How do I subscriber extension mobility service on all the phone in the cluster at one shot?
CCM version: 9.1.2.12901-3
Thanks in advance
Syed
Solved! Go to Solution.
02-14-2017 03:27 AM
Hi Syed,
There is a checkbox "Enterprise Subscription" on the Service configuration page when you add extension mobility service or any other service. Checking this will assign it to all phones, you just need to enable the Extension mobility checkbox on the IP phones.
Manish
02-14-2017 03:56 AM
Hi Syed,
This option is only available at the time of creation of service for the first time. You will need to create this EM service again and then click enterprise subscription.
Manish
02-14-2017 03:27 AM
Hi Syed,
Manish
02-14-2017 03:53 AM
02-14-2017 03:56 AM
Hi Syed,
Manish
02-14-2017 04:01 AM
Perfect answer.
Thank you manish.
