07-03-2017 04:49 AM - edited 03-17-2019 10:41 AM
Hello all,
I have this issue and was wandering does someone else got it?
THE issue:
After upgrade the Extension Mobility is not behaving normal as prior to the upgrade.
IN all the cases - user is logged on without proper confirmation of successful login, in many cases even with errors.
7911 and 7970 after you supply user and password the service menu stays active until you close it manually.
7912, 7906 and 7905 after you supply user and password it pops an error - "Not Available"
7940 after you supply user and password it pops an error - "HTTP error [400]!"
6945 and 6921 after you supply user and password it pops an error - "XML error [4]: parse error"
There is exactly the same error on logout.
I have checked that the extension mobility url is the proper one without spaces.
http://10.100.2.11:8080/emapp/
07-03-2017 06:15 AM
As of version 10.X users need to be checked for "home cluster" on the end user configuration for EM to work properly even if you have a single cluster deployed. So, ensure that is the case.
07-03-2017 06:19 AM
They are checked. They were even in ver. 9 checked as home cluster users.
07-06-2017 12:12 AM
So apparently it was a bug... Working with Cisco TAC to get the fixed release version.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd67978/?referring_site=bugquickviewredir
