Extension Mobility number not following
I have a question regarding extension mobility,  I am setting up extension mobility for the first time and the way I understand it is when a user logs into a phone there number should follow them, the only number i get when logging in is the number from the device profile not the users normal number.  So my question is does everyuser need a device profile? or how do i configure EM to user there number from the controlled device?
mahmoodmkl
Level 7
Level 7
AFAIK u need to configure device profile for each user because the device profile is loaded on the phone.
mahmoodmkl
Level 7
Level 7
Okay thank you I just had to make usre
Look at it this way, EM loads a whole new config on the phone and has no idea of the previous config, so, you only get what you configure in the UDP, there's no way to get the DN the phone had + the DNs you configured with EM.
It's one, or the other.
And yes, every single user needs a UDP if you want them to use EM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
