Extension Mobility - Support over VPN
sean Riley
Level 4
Level 4
Is EM supported while connected via the anyconnect VPN.  I have EM working fine on phones inside the network, but when testing on a phone outside the network connected via the anyconnect VPN I get "Host not found".
Thanks.
7 Replies 7
Jaime Valencia
Can you use the corporate directory or other IP Phone services?
java
if this helps, please rate
Yes, I am able to use the Corp Directory and IPMA services.
I figured it out.  Port on ASA was being blocked.  Got it working now.
Hi Can you let me know which port specifically?
Doing POC and hitting the same issue.
Nasir
Hi Nasir,
Check under “Ip phone services” the extension mobility service url and make sure that port is opened on your firewall.
Also check if Certificate is correctly installed on your IP phone.
Carlo
Please rate all helpful posts "The more you help the more you learn"
thanks for quick reply. I will check that out.
For my setup the CUCM authenticates the user properly shows "login successful" message. and stuck on Phone registration.
I think the next TFTP pull is not working.
note: EM inside LAN setup is working fine. I am able to login with same username and password. The UDP and user association is proper.
