09-04-2018 10:03 AM - edited 03-17-2019 01:25 PM
i see this problem happen frequently. Does anyone recommend any steps to take to attempt to remedy this issue before escelating to ISP? is there anything I can do to dig deeper or resolve the issue myself?
Router1#sh controllers t1
T1 0/1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Data in current interval (273 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 1273 Path Code Violations,
1 Slip Secs, 164 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
241 Errored Secs, 135 Bursty Err Secs, 30 Severely Err Secs, 160 Unavail Secs
T1 0/1/1 is up.
No alarms detected.
Data in current interval (272 seconds elapsed):
36 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
36 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
9200 Line Code Violations, 62 Path Code Violations,
10339 Slip Secs, 18 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins,
10359 Errored Secs, 9 Bursty Err Secs, 0 Severely Err Secs, 9392 Unavail Secs
09-04-2018 10:21 AM
In your output I also see 10339 Slip Secs and 1359 errored secs.
Being your line code configuration correct, I would check physical cabling (try to change the cable between gateway and cpe) and would request e cpe check to your TSP.
Please let me know
Best Regards
Carlo
09-04-2018 10:31 AM
Thank you. Is their anything you recommnd I can do just before I do those things. Does "no mgcp" "mgcp" work? any other commands to reset things?
09-04-2018 10:37 AM
You can try to reset the mgcp gateway and please do a clear counters and execute a show controller t1 again after half an hour to check those errors if they increments.
Please let me know
Carlo
09-04-2018 10:48 AM
Ok thanks. We're tshooting a 1-way voice issue and was wondering if that could be part of the cause
09-04-2018 10:48 AM
09-04-2018 11:33 AM
Thank you. Is their a debug you recommend using to troubleshoot a 1-way voice issue on T1 line?
09-04-2018 11:46 AM
09-04-2018 11:57 AM
RT01#sh voip rtp conn VoIP RTP Port Usage Information: Max Ports Available: 19999, Ports Reserved: 101, Ports in Use: 1 Port range not configured Min Max Ports Ports Ports Media-Address Range Port Port Available Reserved In-use ------------------------------------------------------------------------------ Global Media Pool 8000 48198 19999 101 1 ------------------------------------------------------------------------------ VoIP RTP active connections : No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP MPSS VRF 1 3672 3671 11670 29408 72.1.1.42 172.38.14.38 NO NA Found 1 active RTP connections
Thank you. So when I call them, I don't see anything in the voip rtp connections, but when they call us, i can see the following above I pasted. So the issue is we can hear them, but they can't hear us. So you recommend I try to see if the local IP can reach the remote IP? Like a source ping?
09-04-2018 12:15 PM
If you cannot see any rtp connection during an outgoing call, it means that you are not using that gateway.
Please check your cucm configuration and dialplan to se if you are hitting the correct gateway for outgoing calls.
Please let me know
Carlo
09-04-2018 12:32 PM
09-04-2018 12:38 PM
Sorry, I changed the IPs. One is public, which is the 72.1.1.x and the other is private...it is actually a 172.28 address. correct, this is mpls.
I believe the issue is external and internal. When I call them, we can hear eachother. When they call me, I can hear them, but they can't hear me.
