Extension Mobility
Syed
Level 3
Level 3
Dear All,
I have my CUCM cluster setup in UK and we have extension mobility for all users.
Is there way to find on which desk phone a particular user logged in and I do not want to check with user for this?
Syed
Jitender Bhandari
Hi Syed,
You can go to Cisco Unified Reporting and check the below report for help.
Unified CM Extension Mobility
Provides a summary of Cisco Extension Mobility usage; for example, the number of phones that have a Cisco Extension Mobility user logged in to them, the users that are associated with Cisco Extension Mobility, and so on.
(Rate if it helps)
JB
Thank you JB,
I have generated the report now, but not seeing the user that I want.
Is this current or historical information?
Hi Syed,
See below they might help.
http://www.ucguerrilla.com/2012/06/using-sql-to-validate-cucm-extension.html
https://supportforums.cisco.com/discussion/11671126/cucm-86-extension-mobility-logging
JB
syed you can easily do this
device>phone> click on actively logged in device report on the top right hand side of the page
Select the user profile and you will see the phone the user is logged in to
Please rate all useful posts
