external call forward to an external number is not working fine.
when I try from the external number and forwarding to any external number in CME is not working.
It is a sip call. I am attaching the running-config.
There is a firewall is using for internet connectivity. A normal outgoing call is fine.
CME-2911#sh run
Building configuration...
Current configuration : 25206 bytes
! Last configuration change at 12:44:55 ACST Wed Jul 22 2020 by subnet
! NVRAM config last updated at 13:39:27 ACST Wed Jul 22 2020 by subnet
version 15.7
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname KJKLEGAL-CME-2911
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.157-3.M3.bin
boot-end-marker
no logging queue-limit
no logging buffered
no logging rate-limit
no logging console
--More--  no aaa new-model
clock timezone ACST 9 30
clock summer-time ACDT recurring 1 Sun Oct 2:00 1 Sun Apr 3:00
ip traffic-export profile TACCAPTURE mode capture
bidirectional
incoming access-list BUF-FILTER
outgoing access-list BUF-FILTER
ip dhcp excluded-address 192.168.147.254
ip dhcp excluded-address 192.168.47.252 192.168.47.254
ip dhcp excluded-address 192.168.147.252 192.168.147.254
ip dhcp pool Phones
network 192.168.147.0 255.255.255.0
--More--   default-router 192.168.147.254
option 150 ip 192.168.147.254
dns-server 192.168.47.1
option 66 ip 192.168.47.254
lease 0 4
ip flow-cache timeout active 1
ip domain name .local
ip name-server 192.231.203.132
ip cef
no ipv6 cef
voice-card 0
--More--  !
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 203.2.134.10
ipv4 203.2.134.0 255.255.255.0
ipv4 172.16.1.1
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
call service stop
sip
bind control source-interface Loopback1
bind media source-interface Loopback1
no call service stop
audio forced
--More--  !
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class sip-profiles 1
request INVITE sip-header Diversion modify "<sip:(.*)@172.16.1.1>" "<sip:0873247800@712.16.1.1>"
request INVITE sdp-header Video-Attribute remove
request INVITE sdp-header Video-Bandwidth-Info remove
request INVITE sdp-header Video-Encryption-Key remove
voice class custom-cptone jointone
dualtone conference
frequency 300
cadence 300 50 300 50
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
--More--   cadence 400 50 200 50 200 50
voice translation-rule 8000
rule 1 /^0/ //
voice translation-rule 8001
rule 14 /0873247899/ /300/
rule 15 /0873247/ //
voice translation-rule 8002
rule 15 /^\(.+\)$/ /0\1/
voice translation-rule 8003
rule 13 /860/ /0873247860/
rule 14 /801/ /0873247801/
rule 15 /.*/ /0873247800/
voice translation-rule 8005
rule 1 /^[2-9]......./ /9\0/
rule 2 /^0[2-9]......../ /9\0/
--More--  !
voice translation-rule 8556
rule 2 // /860/
voice translation-profile INCOMING_PSTN
translate calling 8002
translate called 8001
voice translation-profile Incoming_PSTN_Backup
translate called 8556
voice translation-profile Outgoing_Fax
translate called 8005
voice translation-profile PSTN_OUTGOING
translate calling 8003
translate called 8000
vxml logging-tag
license udi pid CISCO2911/K9 sn FGL15351256
--More--  hw-module ism 0
hw-module pvdm 0/0
file privilege 0
username Reception password 7 041949
username admin privilege 15 secret 5 $1$J6Ha$d/GK8UgCf2hUp0obY5Bi2/
username subnet privilege 15 secret 5 $1$BLeZ$6KXP2xRbLx.XtXt495uas/
redundancy
ip tcp path-mtu-discovery
--More--  crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key SZaH2H4VAhYmSmUd address 103.21.48.208 no-xauth
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec df-bit clear
crypto map KJK-VPN 10 ipsec-isakmp
description --- LP Datacentre ---
set peer 103.21.48.208
set transform-set 3DES-SHA
match address KJK-to-LP
--More--  interface Loopback0
no ip address
interface Loopback1
ip address 172.16.1.1 255.255.255.252
ip virtual-reassembly in
interface Loopback2
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
--More--   ip address 192.168.47.254 255.255.255.0
ip helper-address 10.88.208.1
ip flow ingress
ip flow egress
ip tcp adjust-mss 1420
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.147.254 255.255.255.0
interface ISM0/0
description ** Unity Express Service Engine **
ip unnumbered Loopback1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 172.16.1.2 255.255.255.252
!Application: CUE Running on ISM
service-module ip default-gateway 172.16.1.1
no keepalive
--More--   hold-queue 60 out
interface GigabitEthernet0/1
description ---LP Hosted MWAN---
ip address 10.208.0.2 255.255.255.252
ip traffic-export apply TACCAPTURE size 80000000
duplex full
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
--More--  !
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip flow-export source GigabitEthernet0/0.10
ip flow-export version 5
ip flow-export destination 192.168.47.1 9996
ip nat inside source list NAT interface GigabitEthernet0/2 overload
ip nat inside source static tcp 192.168.47.1 25 103.21.51.149 25 extendable
ip nat inside source static tcp 172.16.1.2 80 103.21.51.149 80 extendable
ip nat inside source static tcp 192.168.47.1 25 150.101.99.33 25 extendable
ip nat inside source static tcp 192.168.47.1 443 150.101.99.33 443 extendable
ip nat inside source static tcp 172.16.1.2 80 150.101.99.34 80 extendable
ip route 0.0.0.0 0.0.0.0 10.208.0.1
ip route 172.16.1.2 255.255.255.255 ISM0/0
ip scp server enable
ip access-list standard SNMP-public
permit 192.168.47.0 0.0.0.255 log
ip access-list extended BUF-FILTER
--More--   permit ip host 172.16.1.1 203.2.134.0 0.0.0.255
permit ip 203.2.134.0 0.0.0.255 host 172.16.1.1
permit ip any 203.2.134.0 0.0.0.255
permit ip 203.2.134.0 0.0.0.255 any
ip access-list extended In-From-Internet
permit tcp host 202.189.79.254 any eq 22
permit tcp host 103.21.51.1 any eq 22
remark *** Allow everything back in we initiated outwards ***
evaluate Internet
remark *** Allow everything from Nodephone Hosts ***
permit ip 203.18.11.0 0.0.0.255 any
permit ip 59.167.63.200 0.0.0.3 any
remark *** Allow Subnet Access to Everything ***
permit ip 150.101.53.144 0.0.0.7 any
permit tcp host 103.21.50.188 any eq smtp
permit tcp host 103.21.48.25 any eq smtp
permit tcp host 103.21.50.26 any eq smtp
permit tcp host 103.21.50.25 any eq smtp
permit tcp host 103.21.48.26 any eq smtp
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit esp any any
--More--   permit ahp any any
permit gre any any
deny tcp any any eq smtp
permit tcp any any eq 443
permit udp any any eq ntp
remark *** Block incoming Telephony Services ***
deny udp any any eq 5060
deny tcp any any eq 5060
deny udp any any eq 5061
deny tcp any any eq 5061
deny tcp any any eq 1720
permit icmp any any
permit udp any eq domain any
remark *** Deny Everything else ***
deny ip any any log
ip access-list extended KJK-to-LP
permit ip 192.168.47.0 0.0.0.255 10.88.208.0 0.0.0.255
ip access-list extended NAT
deny ip any 192.168.0.0 0.0.255.255
deny ip any 10.0.0.0 0.255.255.255
permit ip 192.168.47.0 0.0.0.255 any
permit ip 172.16.1.0 0.0.0.3 any
ip access-list extended NO-NAT
--More--   deny ip 192.168.47.0 0.0.0.255 any
ip access-list extended Out-To-Internet
permit ip any any reflect Internet timeout 300
ip access-list extended VOIP-TSHOOT
permit ip 192.168.147.0 0.0.0.255 any
permit udp any any
logging trap debugging
ixi transport http
response size 4
no shutdown
request outstanding 1
ixi application cme
no shutdown
route-map NO-NAT permit 10
match policy-list NO-NAT
snmp-server community public RO
snmp-server community LogicPlus RO
--More--  snmp-server ifindex persist
tftp-server flash:cn
tftp-server flash:term45.default.loads alias term45.default.loads
tftp-server flash:term65.default.loads alias term65.default.loads
tftp-server flash:BOOT894x.0-0-0-9.bin.sgn alias BOOT894x.0-0-0-9.bin.sgn
tftp-server flash:B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:FOC15313X5Q_20110929171149345.lic
tftp-server flash:FOC15313X5Q_20111003182502990.lic
tftp-server flash:SCCP894x.9-4-2SR3-1.bin1.sgn alias SCCP894x.9-4-2SR3-1.bin1.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin2.sgn alias SCCP894x.9-4-2SR3-1.bin2.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin3.sgn alias SCCP894x.9-4-2SR3-1.bin3.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin4.sgn alias SCCP894x.9-4-2SR3-1.bin4.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin5.sgn alias SCCP894x.9-4-2SR3-1.bin5.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin6.sgn alias SCCP894x.9-4-2SR3-1.bin6.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin7.sgn alias SCCP894x.9-4-2SR3-1.bin7.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin8.sgn alias SCCP894x.9-4-2SR3-1.bin8.sgn
--More--  tftp-server flash:SCCP894x.9-4-2SR3-1.bin9.sgn alias SCCP894x.9-4-2SR3-1.bin9.sgn
tftp-server flash:SCCP894x.9-4-2SR3-1.bin10.sgn alias SCCP894x.9-4-2SR3-1.bin10.sgn
access-list 1 permit 192.168.47.0 0.0.0.255
access-list 1 permit 172.16.1.0 0.0.0.3
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
compand-type a-law
cptone AU
timeouts interdigit 5
description ## Fax ##
station-id number 801
caller-id enable
voice-port 0/1/1
--More--   !
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2706 voip
description ** Australian Domestic Pattern via PSTN **
translation-profile outgoing PSTN_OUTGOING
preference 1
destination-pattern 0014[04689].....
session protocol sipv2
session target sip-server
voice-class codec 1
--More--   dtmf-relay rtp-nte
dial-peer voice 2707 voip
preference 1
destination-pattern 0014[12357]......
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2999 voip
translation-profile incoming INCOMING_PSTN
incoming called-number .%
voice-class codec 1
fax rate disable
no vad
dial-peer voice 300 voip
destination-pattern 3..
session target ipv4:172.16.1.2
--More--   dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 400 voip
incoming called-number 40(1,2)...
codec g711alaw
no vad
dial-peer voice 801 pots
translation-profile incoming Outgoing_Fax
destination-pattern 801
port 0/1/0
no register e164
no sip-register
dial-peer voice 2701 voip
preference 1
destination-pattern 0000
--More--   session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2702 voip
preference 1
destination-pattern 0106
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2705 voip
description ** Australian International Pattern via PSTN **
preference 1
destination-pattern 0001[1589]T
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2708 voip
preference 1
destination-pattern 0015......
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2709 voip
description ** Australian Local Pattern via PSTN **
preference 1
destination-pattern 00160..
--More--   session protocol sipv2
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2710 voip
preference 1
destination-pattern 0016[1236789].....
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2711 voip
preference 1
--More--   destination-pattern 0017[1289].....
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2712 voip
preference 1
destination-pattern 0018......
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2713 voip
--More--   preference 1
destination-pattern 00192.
voice-class codec 1
dial-peer voice 2714 voip
preference 1
destination-pattern 00198[45678]
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2716 voip
preference 1
destination-pattern 00[2378]........
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2718 voip
preference 1
destination-pattern 01100
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2721 voip
preference 1
--More--   destination-pattern 0113...
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2723 voip
preference 1
destination-pattern 0119.
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2729 voip
destination-pattern 0180[01]......
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2732 voip
preference 1
destination-pattern 0190[0126]......
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2733 voip
--More--   translation-profile outgoing PSTN_OUTGOING
preference 1
destination-pattern 0[2-9].......
voice-class codec 1
voice-class sip profiles 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2717 voip
preference 1
destination-pattern 004........
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
--More--  dial-peer voice 2720 voip
preference 1
destination-pattern 0110[1-9]..
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2722 voip
preference 1
destination-pattern 0114[012356789]....
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
--More--  !
dial-peer voice 2724 voip
preference 1
destination-pattern 0122[1235]
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2725 voip
preference 1
destination-pattern 0123[46]
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
--More--   no vad
dial-peer voice 2726 voip
preference 1
destination-pattern 0130.......
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 2728 voip
preference 1
destination-pattern 013[1-9]...
voice-class codec 1
dtmf-relay rtp-nte
--More--   fax rate disable
no vad
dial-peer voice 2730 voip
preference 1
destination-pattern 018[59]..
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
sip-ua
credentials username J3978702 password 7 010705530D121C5D7618 realm kjklegal
authentication username J3978702 password 7 071B221B181003574046
no remote-party-id
registrar ipv4:203.2.134.10 expires 3600
sip-server ipv4:203.2.134.10
connection-reuse
--More--   host-registrar
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on *11 mute-off *11
sdspfarm units 4
authentication credential subnet sub$n3t
xml user subnet password sub$n3t 15
max-ephones 25
max-dn 200
ip source-address 192.168.47.254 port 2000
service phone videoCapability 0
service dss
system message KJK Legal
url services http://172.16.1.2/voiceview/common/login.do
url authentication http://172.16.1.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
--More--   load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7945 SCCP45.9-4-2SR3-1S.loads
load 7965 SCCP45.9-4-2SR3-1S.loads
load 8945 SCCP894x.9-4-2SR3-1.loads
time-zone 45
date-format dd-mm-yy
voicemail 300
max-conferences 4 gain -6
call-park system application
call-forward pattern .T
call-forward pattern 3..
call-forward pattern 7..
call-forward pattern 8..
moh enable-g711 "flash:music-on-hold.au"
web admin system name subnet password sub$n3t
web admin customer name Admin password sub$n3t
time-webedit
transfer-system full-consult
transfer-pattern 0.T
transfer-pattern 1..
transfer-pattern 8..
transfer-pattern 7..
--More--   transfer-pattern 3..
secondary-dialtone 0
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn-template 1
call-forward busy 300
call-forward noan 300 timeout 18
ephone-dn 1 octo-line
number 800 no-reg primary
label Reception
description Reception
name Reception
call-forward noan 300 timeout 20
ephone-dn 2 dual-line
number 840 secondary 73247840 no-reg both
--More--   label Irene Glapa
description Irene Glapa
name Irene Glapa
ephone-dn 3 dual-line
number 860 secondary 0873247860 no-reg both
label Amanda Atkins
description Amanda Atkins
name Amanda Atkins
call-forward all 800
call-forward noan 300 timeout 30
ephone-dn 4 dual-line
number 810 secondary 73247810 no-reg both
label Mark Keam
description Mark Keam
name Mark Keam
--More--  !
ephone-dn 5 dual-line
number 820 secondary 73247820 no-reg both
label Tracey Kerrigan
description Tracey Kerrigan
name Tracey Kerrigan
ephone-dn 6 dual-line
number 830 secondary 73247830 no-reg both
label Neville John
description Neville John
name Neville John
ephone-dn 7 dual-line
number 850 secondary 73247850 no-reg both
label Suzana Jovanovic
description Suzana Jovanovic
name Suzana Jovanovic
--More--  !
ephone-dn 8 dual-line
number 870 secondary 73247870 no-reg both
label Boardroom
description Boardroom
name Boardroom
ephone-dn 9 dual-line
number 880 secondary 73247880 no-reg both
label Amanda Atkins
name Meeting Room
ephone-dn 10 dual-line
number 890 secondary 73247890 no-reg both
label Oliver Fragnito
description Oliver Fragnito
name spare
--More--   call-forward busy 300
call-forward noan 300 timeout 10
ephone-dn 11 dual-line
number 895 secondary 73247895 no-reg both
label Server Room
description Server Room
ephone-dn 12 dual-line
number 896 secondary 73247896 no-reg both
label Melanie Conroy
description Melanie Conroy
ephone-dn 150
number 401... no-reg both
mwi on
--More--  !
ephone-dn 151
number 402... no-reg both
mwi off
ephone 1
device-security-mode none
mac-address 0008.3031.CB15
username "Amanda" password 1234
type 7965 addon 1 7916-24
button 1:1 7m2 8m4 9m5
button 10m6 11m7 12m8 13m9
button 14m12 15m3
ephone 2
mac-address 0007.7D42.ECCE
username "IreneG" password 1234
type 7965 addon 1 7916-12
--More--   button 1:10 2m1
ephone 3
mac-address 0007.7D42.E974
username "Server" password 7895
button 1:11
ephone 4
mac-address 0007.7D42.ECB8
username "Mark" password 7810
button 1:4 2m1
ephone 5
mac-address 0007.7D42.E81C
--More--   username "Tracey" password 7820
button 1:5 2m1
ephone 6
mac-address 0007.7D42.E864
username "Neville" password 7830
button 1:6 2m1
ephone 7
mac-address 0007.7D42.E5E8
username "Carmel" password 7850
button 1:7 2m1
ephone 8
--More--   mac-address 0007.7D42.E6A4
button 1:8
ephone 9
mac-address 0007.7D42.E1FE
username "test" password what
button 1:3 2m1
ephone 10
mac-address 1833.9D15.3C6E
button 1:1 2:2 7m12 8m4
button 9m5 10m6 11m7 12m8
button 13m9 14m3
--More--  ephone 11
mac-address 0007.7D42.E6D4
max-calls-per-button 2
busy-trigger-per-button 2
username "Melanie"
type 8945
button 1:12
ephone 100
ephone-hunt 1 sequential
pilot 700
list 800
final 300
no-reg pilot
--More--   vstack
banner login ^C
You are attempting to log on to a secure network device.This
device may only be used for authorised business purposes.
Unauthorised access or use of this device is an offence under
part 10.7 of the Commonwealth of Australia's Criminal Code
Act of 1995 (formerly part VIA of the Crimes Act of 1914).
Anyone found using this device, or information contained
herein, for any unauthorised purpose or personal use may be
subject to disciplinary action and/or criminal prosecution.
^C
line con 0
privilege level 15
transport output telnet ssh
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
--More--   stopbits 1
line 131
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
privilege level 15
login local
transport input ssh
line vty 5 15
privilege level 15
login
transport input telnet ssh
line vty 16 100
login
--More--  !
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 192.231.203.132 source GigabitEthernet0/1
end
-CME-2911# wr
George Sotiropoulos
You may try to add under Telephony-Service the command
transfer-system full-blind
At any case, if you like please enable the "debug ccsip calls" and place the result here to identify the root cause of the failure.
A very useful post with the sip debug command is:
https://community.cisco.com/t5/collaboration-voice-and-video/sip-debugging-commands-overview/ta-p/3155271
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
