06-04-2013 01:29 AM - edited 03-16-2019 05:41 PM
I have an issue with a Call recorder who requires the CDR records that are provided in realtime (through the Billing Server), where they require records going back a couple of months in the same format (i.e. the individual call).
I know I can extract the records in a CSV from CAR (The entire day/month etc), but they have requested the individual files.
Short of creating a MACRO to export each line from the CSV file (Not sure yet how..).
Does anyone know if it is possible to get hold of the individual files retrospectively?
Callmanager version is 7.0
Matt
06-04-2013 07:16 AM
You could get those via CLI,
You use something like this:
file get activelog cm/cdr_repository/processed/20070810/cdr_StandAloneCluster_01_200708100053_1
And you get the individual files before they're processed into CAR DB
Just adjust the date, or use file view to see what folders you have and then pull the info you need.
You probably still need something to automate this.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-04-2013 07:23 AM
@java - automate, but how? Expect?
G.
