FAC Configuration
ricardorojas123
I would like to configure the directory number in the Cisco IP Phone 7961 and CIPC, but I need than the calls from 7961 use FAC and the call from CIPC don´t use FAC.
That is possible?
Directory Number:    7000
Partition:         Internal
Calling Search Space:     External
Route Pattern:
Pattern: 001613XXXXXX
Partition: External
Require Forced Authorization Code: Enable
Selected Partition: Internal, External
Phone Type: 7961 (Phone configured with the DN 7000 PT Internal)
Note: The user enters the FAC.
Phone Type: CIPC (Phone configured with the DN 7000 PT Internal)
Note: The user does not enter the FAC
Leonardo Santana
If you enable the FAC on the route pattern all calls to this pattern will need FAC.
You can create another route pattern without FAC in other partition, create a new CSS and associate this CSS on the device page (CIPC).
Rate this if helps you
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
