07-22-2023 04:31 PM - edited 07-22-2023 04:34 PM
Greetings Community Members,
I am facing this strange issue where i am working for the first time on an authenticated SIP Trunk from STC.
Need your help to solve this issue as even TAC is struggling on this case since 1 week.
They have provided only with Username and password upon further inquiry they provided with the following message saying the registration message should look like this:
Sent:
REGISTER sip:fmc.stc.com.sa SIP/2.0
Via: SIP/2.0/UDP 10.228.56.90:5060;branch=z9hG4bK14AE55
From: <sip:+9661110141198@fmc.stc.com.sa >;tag=4AEC7EF-D4F
To: <sip:+9661110141198@fmc.stc.com.sa >
Date: Tue, 18 Jul 2023 08:14:22 GMT
Although i did know how to do this configuration I tried my best checking all the guides but my registration was going like below
Sent:
REGISTER sip:10.154.15.25:5060 SIP/2.0
Via: SIP/2.0/UDP 10.228.56.90:5060;branch=z9hG4bK32222DF
From: <sip:+9661110141198@10.154.15.25>;tag=A90D606-C54
To: <sip:+9661110141198@10.154.15.25>
Date: Wed, 19 Jul 2023 11:39:00 GMT
Call-ID: FFFFFFFFD862BB79-23E011EE-FFFFFFFF807DBF43-164D5B82
User-Agent: Cisco-SIPGateway/IOS-15.5.2.S3
Max-Forwards: 6
Timestamp: 1689766740
CSeq: 765 REGISTER
Contact: <sip:+9661110141198@10.228.56.90:5060>
Expires: 3600
Supported: path
Content-Length: 0
I opened a case with Cisco Tac a week back they responded it needs SIP profiles to be configured and now after 1 week we are still struggling to send the register message in the required format.
I have attached my current configuraiton.
After all Cisco TAC did we could send the register message as below and we recieved 403 Forbidden message
Jul 20 14:12:21.905: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.189.133.50:5060;branch=z9hG4bK21A24
From: <sip:+9661110141198@10.154.15.25>;tag=6E79F-392
Date: Thu, 20 Jul 2023 14:12:21 GMT
Call-ID: 6DFA5FA3-263D11EE-FFFFFFFF8002C517-FFFFFFFFA5150B52
Max-Forwards: 70
Timestamp: 1689862341
CSeq: 4 REGISTER
Contact: <sip:+9661110141198@10.189.133.50:5060>
Expires: 3600
Supported: path
Content-Length: 0
Jul 20 14:12:22.026: //5/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
To: <sip:+9661110141198@10.154.15.25>;tag=eed7nn3e
CSeq: 4 REGISTER
Warning: 399 5133.1261.I.260.12.165.4.7.5134.0.0.fmc.stc.com.sa "Invalid User"
Content-Length: 0
Need your support.
Thanks.
Solved! Go to Solution.
07-28-2023 06:34 AM
Any update on this?
07-26-2023 02:23 AM - edited 07-26-2023 11:15 PM
Try with adding this to correct what I mentioned in my prior post.
voice service voip
ip address trusted list !Security for your SBC so that it can't be used for toll-fraud
ipv4 10.228.56.96
ipv4 10.228.56.95
ipv4 10.154.15.25
mode border-element license capacity X !Turns on CUBE functionality. Put what you need to handle the maximum simultaneous calls or use a newer IOS version that does not need the capacity to be set as part of this command
sip
bind control source-interface GigabitEthernet0/0/1
bind media source-interface GigabitEthernet0/0/1
voice class uri CM
host ipv4:10.228.56.96
host ipv4:10.228.56.95
voice class uri ITSP
host ipv4:10.154.15.25
voice class sip-options-keepalive 1
description Used for SIP option ping with a server group
voice class server-group 1
ipv4 10.228.56.96 preference 1
ipv4 10.228.56.95 preference 2
dial-peer voice 3 voip
description ***Outbound calls to ITSP***
no codec g711alaw
voice-class codec 1
dial-peer voice 4 voip
description ***Inbound calls from ITSP***
no incoming called-number +966.T
incoming uri via ITSP
dial-peer voice 11 voip
no preference 1
no session transport udp
no session target ipv4:10.228.56.96
voice-class sip options-keepalive profile 1
session server-group 1
dtmf-relay rtp-nte sip-notify sip-kpml
no dial-peer voice 12 voip
dial-peer voice 10 voip
description ***Outbound calls from CUCM***
session protocol sipv2
incoming uri via CM
voice-class codec 1
no vad
sip-ua
no registrar dns:fmc.stc.com.sa expires 3600
no sip-server dns:fmc.stc.com.sa
registrar ipv4:10.228.56.90 expires 3600
voice class tenant 1
no ip route 10.154.15.25 255.255.255.255 10.189.133.49
ip route 0.0.0.0 0.0.0.0 10.189.133.49
ip domain lookup
domain name-server interface GigabitEthernet0/0/1
ip name-server X ! your DNS server that the gateway can reach on the inside interface
Also I would when you get this working advise you to create an access list that you set on the outside interface, is the one facing your ITSP, so that you only allow the needed traffic coming from the known entitie(s) at your ITSP. Normally that would be allow SIP signaling and RTP traffic for the media of the call.
11-27-2023 03:14 AM
Hi Abdul Malik,
Hope your issue is resolved by now, is it possible for you to share your final working configuration here with us, as I am also going to implement the new stc sip trunk. Highly appreciate your help.
