05-08-2018 08:16 AM - edited 03-17-2019 12:46 PM
hi all,
i just deployed a PCD server 11.5, but when i want to add esxi host, eror come :
Failed to mount Cisco Prime Collaboration Deployments export as NFS store to the ESXi Host. Please look at the exception details in PCD logs and check the ESXi logs for further details of the exceptions reported on PCD.
Can you help me
thanks
05-08-2018 08:45 AM
Hi there
PCD is not compatible with all license types of VMware vSphere ESXi, because some of these licenses do not enable required VMware APIs. The PCD Admin Guide incorporates compatible licenses.
The following are compatible with Cisco Prime Collaboration Deployment:
The following are not compatible with Cisco Prime Collaboration Deployment:
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
05-08-2018 05:03 PM
05-08-2018 06:01 PM
Are you utilizing dns as part of your pcd install?
I can’t see logs but I had a problem with dns and pcd a while back where I believe no it was the esxi host was not returning properly.
05-08-2018 06:52 PM
hi Brunn,
i didnt configure for DNS
thanks
05-09-2018 03:04 PM
Hi there
There is a post with a workaround. try the below
I solved it by disabling my hypervisor license and went to Evaluation mode which lets you proceed.
Hope this helps!
Cheers
Rath!
05-09-2018 05:23 PM
hi rath,
thanks for replied,
i already did, but not working, problem still happened.
any idea?
thanks
09-07-2020 10:24 AM
When I tried to delete the license, the license key and features disappeared, but still license validity showing never expires. Looks like the license was not changed to evaluation mode when I removed the license key from the esxi. may be this is the reason why the issue is still there. Any thoughts ?
09-10-2020 09:58 AM
What about vCenter?
