failover publisher/subscriber?
lukeprimm
Need a little help with my PUB and SUB.  Should I be able to run a DR test on say my PUB or SUB and have the other take over?  So If I were to turn off my subscriber, would the publisher still keep the phones ringing and the other way around?  Thanks
Yes if you configure the call manager group to have both call managers in the list and that call manager group is on the device pool you configure for these ip phones.
Amer
thanks, is there a quick place to look to verify the settings you mentioned above? thanks
There is something called call manager group , check the groups you created or you want to create , when you enter the config of the group , you can select the call managers and then reorder them as you want.
To let this be affective , on the device pool config , select the group you want so when the phone get's the device pool , he will get this config along with the region (for codecs) , location , SRST reference (if applicalble) and the most important is the media resources.
Amer
