Gateway IP to PSTN
Osman_gadji_2
Hi guys!
I have a Cisco 2811 router (C2800NM-ADVIPSERVICESK9-M, Version 12.4 (18) and the PBX.
In our office comes four analog line from a very old PSTN. line is pulse.
Tell me, what Network Module/Interface Card should be used to connect analog lines, PSTN?
2 Accepted Solutions
Faheem Ansari
if you need to connect PSTN with Cisco Router... you require 4 port FXO module, it could be VIC3-4FXO or VIC2-4FXO with IP Voice Services IOS.
don't forget to rate the helpful answer
Regards.
I stand corrected, it's supported.
voice-port x/x
dial-type pulse
10 Replies 10
Faheem Ansari
Regards.
Thanks.
With this module, can i configure some interfaces as tonal, and others as a pulse?
I am live in russian, have any exceptions when configuring module?
Can you recommend resource where i can find documentation?
Thanks.
If you want to connected the PBX you will also need FXS interfaces.
You will also need PVDM2 modules.
In any case, recommend you engage a reputable consultant or certified cisco partner, otherwise you will run into many difficulties, and the results will be poor.
you can find documentation from Cisco.com under Support>Configure Tab, but i would to recommand some pure Cisco Techie fo this JOB.
Faheem Ansari
For connecting PBX, i can use ip. My PBX is a IP-software based.
Why i need a PVDM2 modules?
Because they are DSP.
No DSP, No VoIP.
ok, thanks, understand!
Are you sure, that Cisco gateway is no support for pulse dialing?
voice-port x/x
dial-type pulse
Okay.
Guys, thanks very much
Thank you for the nice rating and good luck!
