01-31-2011 08:42 PM - edited 03-16-2019 03:11 AM
if route a call to a gatekeeper via a dial-peer voice X voip and it fails, is there a way to automatically fail it over to a dial- peer voice X pots to send it over the PSTN.. will preference work between voip and pots dial-peers?
01-31-2011 08:43 PM
apology for the small fonts
01-31-2011 10:49 PM
As long as the destination pattern is the same in both the dial-peers, the preference command will hold good. Hence you can do something like this:-
dial-peer voice 1 voip
destination-pattern 9.T
session target ipv4:X.X.X.X
dial-peer voice 2 pots
port 0/1/0:23
Hope that helps
Nitesh
PS:Pl rate helpful posts
01-31-2011 10:57 PM
I have checked this but It didn't work
dial-peer voice 2618 pots
trunkgroup PSTN_OUT
corlist outgoing call-domestic
description ** AUDP National Pattern via PSTN **
translation-profile outgoing STRIP_0_OUTGOING
preference 2
destination-pattern 004........
no digit-strip
no sip-register
dial-peer voice 5000 voip
description ** Testing GSM Gateway**
b2bua
session protocol sipv2
session target ipv4:192.168.5.20
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
If I disconnect GSM gateway and call 04 pattern it wont dial out via PSTN.. works ok when GSM is up.
Its still picking up 5000 dial peer even if it doesnt respond
any clues???
02-01-2011 12:57 AM
Post the output of the 'show dial-peer voice summary' and ' debug voip ccapi inout' when the WAN link is down and a test call is made.
Meanwhile i will try this out in my lab.
Nitesh
02-01-2011 12:43 PM
Still waiting for your outputs. By the way i tested and found out that if the destination address (192.168.5.20) is not pingable when the gateway tries to route a call to it, then it will automatically failover to the next dial-peer(2618 in your case). The failover actually takes sometime, so we should be patient.
You said that If you disconnect GSM gateway and call 04 pattern it wont dial out via PSTN- what exactly do you hear??
Post the output of 'debug voip ccapi inout' and 'debug voip dialpeer' for a test call with the GSM gateway disconnected.
Hope that helps
Nitesh
PS: Pl rate helpful posts
02-01-2011 01:44 PM
Below is the link that explains how to configure failovers in dial-peers.
http://www.cisco.com/en/US/docs/routers/access/as5350/software/feature/guide/pulcfgtm.html#wp1044055
It involves the following config:
Creating a voice class and assigning a timeout value
voice class h323 1
h225 timeout tcp establish 10
Applying the voice class in the dial peer
dial-peer voice 919 voip
application session
destination-pattern 919555....
voice-class codec 1
voice-class h323 1
session target ras
Karthic.R.S
