Failure to receive or call out (Critical)
I am getting the following error, periodically in my CME deployment: %SIP-3-MEMCAC: call rejected due to CAC based Memory usage, sent response 503
This results in a total failure to make or receive any calls!
Kindly see attached memory commands and advise.
Refer to attached file for output of similar commands during the error period.
Thank you Jaime,
I am more attached to the community than to TAC. Will have to change my mindset I guess!
Thank you for that reference, I will adjust the threshold and update.
Jaime Valencia
If you have something like this configured:
call threshold global total-calls low 20 high 40
See here
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/vcr1/vcr1-cr-book/vcr-c3.html#wp542
8933540
BTW, if this is really critical and urgent, you should be calling TAC, or you support team.
java
if this helps, please rate
So after 7 hours with Cisco TAC we ended up fixing the failed calls due to memory threshold exceeded issue by removing any call threshold commands on the CUBE.
