fax losing pages
VPMaharaj
We are losing fax pages intermittently and it appears that this is happenning when someone faxes from a Rightfax i.e from a PC Fax software similar to Winfax though we are still trying to pinpoint it exactly. It all was working fine and we have not changed the 2811 configs. Problem appeared couple of days ago.We have a CM cluster and the 2811 connects to a 30 ch PRI to access the PSTN and uses H.323 i.e no MGCP. I cannot see any slip etc errors on the serial interface.
Any help would be great. The faxes are coming from various external organisations via the PSTN link. Would the Call Manager be involved in such a fax call?
Erick Bergquist
Level 6
Level 6
Check the controller stats, for slips or any errors on both the connection to RightFax and the PSTN connection.
Is call going over your network (not pots to pots leg in same gateway). If so, are you using FAX passthrough or FAX relay across the network between PSTN gateway and where the handoff to RightFax is?
Hi Eric,
Many thanks for the reply.
The calls are coming in vice the isdn (pstn) and going out to the fax machine via POTS dial peer to a voice port on a FXS card. I have pasted the config below:
SYD-VG1#sh run
Building configuration...
Current configuration : 5936 bytes
version 12.4
service password-encryption
hostname SYD-VG1
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 5 $1$N2ko$RKmgz0wi53YCnb9FYfHjN0
no aaa new-model
resource policy
clock timezone AEST 10
clock summer-time AEST recurring last Sun Oct 1:00 last Sun Mar 1:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip multicast-routing
isdn switch-type primary-net5
voice-card 0
dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
fax protocol pass-through g711alaw
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
call preserve
voice translation-rule 2
rule 5 /^293209\(...\)/ /40\1/
rule 6 /^93209\(...\)/ /40\1/
voice translation-rule 3
rule 1 /\(.........\)/ /00\1/
voice translation-profile in-called
translate calling 3
translate called 2
controller E1 0/0/0
pri-group timeslots 1-31
interface FastEthernet0/0
description LAN Connection
ip address ####
ip pim sparse-dense-mode
duplex full
speed 100
h323-gateway voip interface
h323-gateway voip bind srcaddr ####
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip route 0.0.0.0 0.0.0.0 ####
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap notifications
logging facility syslog
access-list 23 permit ***
snmp-server location Sydney
control-plane
voice-port 0/0/0:15
translation-profile incoming in-called
echo-cancel coverage 32
cptone AU
timeouts interdigit 4
voice-port 0/1/0
no comfort-noise
cptone AU
description FAX1
voice-port 0/1/1
no comfort-noise
cptone AU
description FAX2
voice-port 0/1/2
no comfort-noise
cptone AU
description FAX3
voice-port 0/1/3
no comfort-noise
cptone AU
description analog-phone
ccm-manager music-on-hold
dial-peer voice 100 pots
destination-pattern 0T
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 200 voip
description To Subscriber
destination-pattern 40[3-6]..
voice-class codec 1
voice-class h323 1
session target ipv4:10.32.192.2
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 201 voip
description to Publisher
preference 5
voice-class codec 1
voice-class h323 1
session target ipv4:10.32.192.1
fax rate disable
no vad
dial-peer voice 40321 pots
destination-pattern 40321
fax rate disable
port 0/1/1
dial-peer voice 40469 pots
destination-pattern 40469
fax rate disable
port 0/1/0
dial-peer voice 40511 pots
destination-pattern 40511
fax rate disable
port 0/1/2
dial-peer voice 40520 pots
destination-pattern 40520
fax rate disable
port 0/1/3
banner login ^CCCC
Cannot see any errors or slips as well.
SYD-VG1#sh controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (4 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
SYD-VG1#
I will reset the router later.
