01-28-2020 03:02 PM
Hello Support community,
We would like to enforce the FAX RATE on the CUBE for all the calls. I know that the "Fax Rate <rate>" command on the dial-peers would do but I would like to know if there is any possibility to go it on the Global Configuration such as on "voice service voip" to avoid individual configuration on each Dial-peer.
The call flows are.
Incoming:
ITSP ---> CUBE ---> CUSP ---> CVP / CUCM
Outgoing:
CUCM ---> CUBE
01-28-2020 05:06 PM
I remember there is global command for Pots but did not find for VOIP. In your case 'Voice service Pots' will be not required since you are using VOIP dial-peer.
01-29-2020 09:24 AM
