Fax sending not possible with VG202 (SCCP) - But Receiving Fax is working
Kevin_W
Hello Community,
do you have any idea how to troubleshoot or solve this issue/scenario?
We have a Cisco VG202XM, which has a fax connected on port 0/0.
The PSTN gateway is a virtual Cube.
The Call Manager is  running with version 11.5.
We can successfully receive a fax, but we are not able to send.
While trying to send we will get with debug voip ccapi inout:
Apr 11 13:47:27.900: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x873FA61C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=999200
Apr 11 13:47:27.900: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Apr 11 13:47:27.900: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@7793
Apr 11 13:47:27.904: //-1/2DDA9F048029/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Apr 11 13:47:27.908: //-1/2DDA9F048029/CCAPI/cc_api_call_setup_ind_common:
Interface=0x873FA61C, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=999200, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 11 13:47:27.908: //-1/2DDA9F048029/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 13:47:27.908: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 13:47:27.908: :cc_get_feat
Voicegateway_VG202#ure_vsa malloc success
Apr 11 13:47:27.908: cc_get_feature_vsa count is 1
Apr 11 13:47:27.908: :FEATURE_VSA attributes are: feature_name:0,feature_time:2278519792,feature_id:13
Apr 11 13:47:27.908: //13/2DDA9F048029/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Apr 11 13:47:27.912: //13/2DDA9F048029/CCAPI/cc_process_call_setup_ind:
Event=0x873AAC00
>>>>CCAPI handed cid 13 with tag 999200 to app "stcapp"
Apr 11 13:47:27.912: //13/2DDA9F048029/CCAPI/ccCallSetupAck:
Call Id=13
Apr 11 13:47:27.912: //13/2DDA9F048029/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Apr 11 13:47:27.956: //13/2DDA9F048029/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Internal Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=13
Apr 11 13:47:27.956: //13/2DDA9F048029/CCAPI/ccCallReportDigits:
(callID=0xD, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=13
Apr 11 13:47:27.956: //13/2DDA9F048029/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x873FA61C, callID=0xD, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x873FA61C, Call Id=13
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Voicegateway_VG202#
Apr 11 13:47:33.376: //13/2DDA9F048029/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x873FA61C, Call Id=13
Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Apr 11 13:47:33.376: //13/2DDA9F048029/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=13
Apr 11 13:47:33.376: //13/2DDA9F048029/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Apr 11 13:47:33.412: //13/2DDA9F048029/CCAPI/ccGenerateToneInfo:
Apr 11 13:47:33.416: //13/2DDA9F048029/CCAPI/ccCallFeature:
Feature Type=34, Call Id=13
Apr 11 13:47:33.416: //13/2DDA9F048029/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Apr 11 13:47:33.416: //13/2DDA9F048029/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Voicegateway_VG202#
Apr 11 13:47:33.420: //13/2DDA9F048029/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x873FA61C, Tag=0x0, Call Id=13,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Apr 11 13:47:33.420: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 13:47:33.420: :cc_free_feature_vsa freeing 87CF73E8
Apr 11 13:47:33.420: vsacount in free is 0
Our VG202 configuration is:
version 15.4
no service pad
service password-encryption
hostname XXXXX
boot-start-marker
boot system flash:vg20xxm-ipvoice-mz.154-3.M5.bin
boot system flash:vg20xxm-ipvoice-mz.156-3.M3a.bin
boot-end-marker
no aaa new-model
clock timezone GMT 1 0
clock summer-time MEST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/0
fallback-dn +49XYZ
stcapp call-control mode feature
voice service voip
fax protocol none
modem passthrough nse codec g711alaw
voice-card 0
archive
log config
hidekeys
username root privilege 15 secret 0 XXXX
interface FastEthernet0/0
ip address A.B.C.D 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway "DefaultGateway"
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 "DefaultGateway"
control-plane
voice-port 0/0
no vad
compand-type a-law
no comfort-noise
cptone DE
timeouts ringing infinity
bearer-cap 3100Hz
caller-id enable
voice-port 0/1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local FastEthernet0/0
sccp ccm "cucm01-IP" identifier 2 version 7.0
sccp ccm "cucm02-IP" identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
ccm-manager sccp local FastEthernet0/0
dial-peer voice 999200 pots
no tone dialtone remote-onhook
tone busytone remote-onhook
service stcapp
port 0/0
dial-peer voice 999201 pots
service stcapp
port 0/1
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
logging synchronous
login local
transport input telnet
ntp server XXXX prefer
ntp server XXXX
end
If you need to know any further information (e.g. Call Manager settings), feel free to ask.
Thank you very much for any help/hint.
Kevin_W
Hello everybody,
For those, who are facing the same problem, I solved the issue:
Following is the correct configuration (compared to the config in my post before):
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
modem relay nse codec g711ulaw gw-controlled
By the way: Also the fax device was not working properly. With an other fax device and the configuration above, everything works. Please be aware, that also the configuration of the fax (prefix and connection) needs to be correct.
bsrohan
You can check this troubleshooting guide, it has a detailed information on the message flow and debug messages to look,
https://www.cisco.com/c/en/us/support/docs/voice/skinny-call-control-protocol-sccp/118646-technote-sccp-00.html
Hope this Helps !
-Rohan
Kevin_W
Hello everybody,
voice service voip
