Fax server and Fax machine setup with MGCP and voice gateway 2901
yeruel77
Hi Team,
I need your support.
I am just trying to setup Fax server. Fax server roles and services mmanager deployed in windows server 2012 r2.
Voice gateway 2901 is installed as MGCP analog gateway with consists of 2 FXS and 4 FXO cards. FXO cards connected directly with PSTN lines.
and FXS card connected directly to FAX machnes. is it right senario?
But to how to integrate this senario with Fax server. just to send and recieve from PC using fax server i need to integrate. what things shall I do on this senario?
Thanks in advance.
5 Replies 5
Niraj Rathod
You need to procure FAX server service over CUCM from third party vendor, they will provide you configuration required at CUCM and VG end.
Thanks !!
which vendor is suitable for my senario? please suggest me with recources.
You can check for our Fax Server solution here:
http://www.commsouth.com/downloads/IPFaxServer_Brochure_EN.pdf
If you have any queries, please do let me know (prasana@commsouth.com)
Prasana Kumar. P
(please rate if useful)
Regards, Prasana Kumar.P +919841027006
Hi Thanks,
i have just sent email.
is your solutions intagrate with our UC according to the above senario.
I just replied to your email as well.
Prasana
