TRANSFER IS TO IS BUSY
raxa.nathani
We are using a CME on 2901 Router.  The problem is that when a call is transfer on any phone which already have two placed calls, then the third call is not transferred and the phone says, "Transfer Is To is Busy". We have configured blind transfer in our telephony services and do not want to work with full consult due to some reasons.
Call flow
PSTN---FXO--Voice Gateway---SIP trunk--CME--SCCP Phone
telephony-service
sdspfarm units 10
conference hardware
max-ephones 26
max-dn 50
ip source-address 10.200.15.61 port 2000 secondary 10.128.239.245
service dss
load 7916-24 B016-1-0-4-2.SBN
load 7942 SCCP42.9-4-2SR1-1S
load 7962 SCCP42.9-2-3S.loads
time-zone 37
date-format dd-mm-yy
max-conferences 8 gain -6
moh enable-g711 "flash:en_bacd_music_on_hold.au"
multicast moh 239.1.1.1 port 2000
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern 5...
secondary-dialtone 9
create cnf-files version-stamp 7960 Dec 05 2016 13:25:56
As per the debugs
073630: Dec 5 11:56:17.363: ephone-22[21/10][SEP0C1167232CFE]:CollectTransferDigits done (4) on DN 21
073631: Dec 5 11:56:17.363: SkinnyGetCallState for DN 24 chan 1 HOLD
073632: Dec 5 11:56:17.363: called DN -1 chan 1, calling DN -1 chan 1 phone -1 incoming s2s:0
073633: Dec 5 11:56:17.363: SkinnyGetCallState for DN 24 chan 1 HOLD
073634: Dec 5 11:56:17.363: called DN -1 chan 1, calling DN -1 chan 1 phone -1 incoming s2s:0
073635: Dec 5 11:56:17.363: SkinnyGetCallState for DN 24 chan 2 IDLE
073636: Dec 5 11:56:17.363: called DN -1 chan 1, calling DN -1 chan 1 phone -1 s2s:0
077581: Dec 5 11:56:50.503: Skinny Call State change for DN 21 chan 1 IDLE from CONNECTED
077512: Dec 5 11:56:43.803: PredictTarget match 8251 DN 21 not idle: CONNECTED
073639: Dec 5 11:56:17.363: ephone-22[21/10][SEP0C1167232CFE]:Can't transfer to busy DN 21
073640: Dec 5 11:56:17.363: ephone-22[21/10][SEP0C1167232CFE]:DisplayMessage: Transfer-To is Busy (19/20)
Any help will be appreciated
raxa.nathani
Is there any one to answer?
Are you using dual-line or octo-line for the phones?  Do you have any hard-set busy trigger configurations?
I am using octo lines and no hard set configurations is there. I opened a TAC case and same problem occurred when they tested in their lab.
TAC has forwarded the case to the next level and soon i will share the results.
